Home > My Range Rover > 2k for 06 4.2sc
Page 4 of 8 <12345678>
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Well I'd say this fan nut is on good and proper. Certainly putting up a fight
Soaked the nut with some Jesus juice (wd40) tonight and going too see of I can find a hgv shop to get a decent 36mm spanner from so I can see if I can "shock" the nut and release it.
Correct me if I'm wrong but these go anticlockwise right on the 4.2 sc
Post #600785 15th Jul 2021 7:37pm
dingg1
No pretend your tightening it and it'll come off lh thread
Post #600807 15th Jul 2021 9:16pm
Bean19844
I done some reading on the Internet and they all said it was a rh thread
Post #600814 15th Jul 2021 9:50pm
dhallworth
I ordered the tool from PowerfulUK to hold the pulley and then had a viscous fan spanner that I’ve had since my P38 days. It took a good whack with a lump hammer to get it to shift. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #600815 15th Jul 2021 9:52pm
Bean19844
I ordered the same one David. Don't suppose be much more progress now until next week though
Post #600816 15th Jul 2021 10:00pm
dingg1
MY APOLOGIES , you're correct I must be thinking of the bmw engine or had a brain fart Embarassed
Post #600843 16th Jul 2021 8:01am
dingg1
Try this method
Hth
Post #600847 16th Jul 2021 9:21am
Bean19844
Cheers for the replies gents. I went to powerful and ordered this puppy.
Tap tap and
Sadly from maltings the viscous fan hasn't turned up after issues from parcelforce but as I suspect the fan shroud don't normally appear to be in 4 various pieces
Hopefully tomorrow I'll get the pump and belts off and get it put back together
Post #601173 19th Jul 2021 6:52pm
Bean19844
Well after the daily decided to throw a wobbly this weekend by cooking the alternator, battery and now it's overheating so left that on its own for the time being and decided to carry on with the supercharged. Managed to get the water pump and the belts off today but then the heavens decided to open and flood the road so thought this would be a good time to down tools.
Decided with a bit of help and persuasion from a few members on here that I should purchase the flappy paddle gear selector modification off another member on this site.
Other then that I've just purchased the supercharger oil change kit so I'll get that changed soon as it turns up.
Hopefully I'll get a few early finishes this week and will get this motor up and running this week. Apart from the engine bay work, just need too fit the side bars and getbthe thing taxed. £600 for a year is going to hurt though
Post #601799 25th Jul 2021 8:24pm
Bean19844
Well had an early finish today from work so decided I'd get some of the car done this evening. Managed too get the water pump on and both belts put back on. Have too admit the tensioner is definitely the easiest one I've ever done in the past with a trust 3/8 ratchet.
Didn't realise the fan cowling come in two separate parts. Hopefully tomorrow I'll be able too get the viscous fan and the shroud back on tomorrow. Should have the supercharger oil kit delivered tomorrow as well so that's the plan for tomorrow night.
Decided too call it a night here as I've gotta re bleed the 4.4 as that's currently overheating after changing the alternator plus the flying ants are starting too irritate me 😆🤣😂
Post #601897 26th Jul 2021 6:55pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Going in the right direction Thumbs Up
Post #601898 26th Jul 2021 7:35pm
Bean19844
Sure is Mr Glover
Managed too refit the viscous fan, cowling and the airbox tonight. Charger oil turned up today so tomorrow's job will be get another battery for the range as the daily done the alternator and the battery so the charger battery is on the daily now but while I'm at it I'll grab the 3/16 hex key required to get to the blower to do the oil.
Anyways time to do a list on costs so far most of which wasn't essential if I'm honest
£2000 car
£115 fan cowling
£157 viscous fan
£33 water pump
£33 belts x2
£26 s/c oil
£18 viscous locking tool
£30 36mm spanner and other assortments
£40 coolant
£100 hsb020 yuasa battery
£2542
£125 side bars
£175 flappy paddle set up
£300
Total £2842
So at present I'm at sub 3k for a working super charged range rover. Pretty happy with that but soon the big one is due, car tax and a trip too see Mr hinds at Dartford transmission auto Centre to get the box flushed and a check over for anything else that's likely too cause me any trouble.
Post #602014 27th Jul 2021 6:33pm
PlaceDuPilori
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
And what is the latest update with this project? Seems like a proper result... fingers crossed!
Post #602271 30th Jul 2021 9:14am
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
I'm following this thread with interest.
I didn't get mine as cheap as yours but I'll be doing a big service soon and think she's due a gearbox flush as well.
Then externally getting the SC back to standard spec. 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
2008 D3 HSE Stornoway Grey (UK)
2008 D3 HSE Izmir Blue (ZA/Zimbabwe)
1995 D1 300 Tdi (Zimbabwe)
Post #602281 30th Jul 2021 10:58am
Bean19844
So managed too get the sc up and running today as well as fitting the paddle kit. Done the supercharger oil change but then I realised I made a bit of a mistake. The car is sitting on a slight incline on the drive way so scrapped that idea after I could only get 30ml of oil out.
Car still seems too be running up on the temperature at present though. Seen as it's on an incline I'll leave the cap off n let gravity do its own thing over night.
Feeling a bit excited thought too try the paddle kit soon as its been to have the gearbox done
Paddle shifter works a treat.
Viscous fan running
https://youtube.com/shorts/54AuMbnSFvQ?feature=share
One more job tomorrow which is getting the side bars fitted to the chassis.
Sound system sounds pretty nice altho it sounds like there's a bit of static interference on the radio stations
Post #602436 31st Jul 2021 7:32pm
