![]() | Home > Maintenance & Mods (L322) > Lower Tailgate Switch Rubber Cover |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
Hi All,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
it is fiddly to put back in and if you cant do it then take the trim off and fit it . ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
I seem to remember getting mine on with the end of a cake slice. What a faff 🤣
Just looking at the trim, are those plastic plugs covering screws ? I’m just wondering how to re,I’ve that lower tailgate trim section. Thx ------------------------------------- MY 2012 4.4 TDV8 |
yes they are little screw caps..prise them off and you'll see the screw head . ... - .- -.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1223 ![]() ![]() ![]() |
With a little bit of silicone lube give it a bit of wiggling and it will pop into place, although it does fight back a wee bit |
Thanks all, Job Done !!
