Home > Maintenance & Mods (L322) > Lower Tailgate Switch Rubber Cover
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Hi All,
My Lower Tailgate Switch stopped releasing the lower tailgate.
I managed to open, test and prove the lower tailgate mechanism with the GAP IiD tool and then having removed the rubber switch cover, I found that the switch was getting stick down. A blast with a air compressor has fixed the switch, but now I can’t get the damn rubber cover back in !!
Any suggestions or tips on the method to do that ?
[/img] -------------------------------------
MY 2012 4.4 TDV8
Post #597404 14th Jun 2021 6:52am
it is fiddly to put back in and if you cant do it then take the trim off and fit it . ... - .- -.
Post #597406 14th Jun 2021 6:56am
mpirie
+1 it's easier to take the plastic trim off to make sure the little rubber tabs are located properly, then refit the trim.
Mike
Post #597414 14th Jun 2021 7:31am
mjdronfield
I seem to remember getting mine on with the end of a cake slice. What a faff 🤣
As Stan says, take the trim off if you want to get to the underside for a good fit.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #597418 14th Jun 2021 8:17am
bwelton
Mike
Just looking at the trim, are those plastic plugs covering screws ? I’m just wondering how to re,I’ve that lower tailgate trim section.
Thx -------------------------------------
MY 2012 4.4 TDV8
Post #597451 14th Jun 2021 12:19pm
yes they are little screw caps..prise them off and you'll see the screw head . ... - .- -.
Post #597455 14th Jun 2021 12:26pm
Merchy
With a little bit of silicone lube give it a bit of wiggling and it will pop into place, although it does fight back a wee bit Thumbs Up
Post #597460 14th Jun 2021 12:40pm
bwelton
Thanks all, Job Done !!
The plastic caps pop off the screw.
MY 2012 4.4 TDV8
Post #597465 14th Jun 2021 12:56pm
