Home > In Car Electronics (L322) > Playing MP3 files from USB stick
p-trax
Japan 2011 Range Rover Vogue 4.4 V8 Santorini Black
I decided to get a 32GB mem key and fill it with MP3 files, and leave this permanently connected in the car.
After successfully testing with a handful of files in the root of the key, I went ahead and converted 10GB of M4a files to MP3.
I then created a similar folder structure to that of my existing MP3 library (artist/album/track title), and moved this onto the key.
In total this took around six hours!
Only now the Range Rover system cannot see any playable content, in fact it sees the root as empty?
I suspect that the system cannot read subfolders ( although it supports this within the iOS devices), but it is also possible that it supports no folder structure at all?
I have read around and general consensus is that (despite land rovers claims) mixed formats are not supported, not an issue for me as all files are MP3.
I also found this; http://www.youtube.com/watch?v=eq9bBb4W1x8...ata_player which looks like an official LR video. This suggests that folders are supported.
Before I spend another couple of hours "unstructuring" the library I though I'd see if you guys had any expiences to share?
It would be a complete bunch of @r$€ if all tracks have to sit in the root, giving no album/artist search possibilities. Gerry
____________________________________________
Arrived>Santorini/Jet FFRR MY11 TDV8
Gone>Stornaway/Ebony MY09 RRS HST TDV8
Gone>Java black/Ebony MY07 RRS HSE TDV6
Post #64433 17th May 2011 10:17pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
I have a more modest 4gb usb stick with 13 double albums on it. Each album in its own folder with each disc in its own sub folder for example Album 001 with subfolder 001-CD1 and 001-CD2. If I skip a track it moves onto the next track or if its the last track in a folder it plays the first tract in the next folder.
The Portable Audio Device option when selected displays the folders on the right hand side then when selected the sub folders and then the tracks. Thumbs Up
Could it be the system cannot cope with 32gb Rolling Eyes
I can't believe I am mad enough to be posting a reply this late or more importantly that I unlocked the front door and went out to my car just to check to make sure Shocked Shocked
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #64440 17th May 2011 10:34pm
p-trax
Thanks for checking Thumbs Up
It's seem s odd that it could read 1 albums worth of tracks, but cannot cope with multiple folders? Gerry
Post #64442 17th May 2011 10:45pm
Andy.
I'm with Andy on this theory, 32Gb is big for an ageing system to cope with.... Got - 2017 SDV8 Autobiography in Loire Blue
Post #64445 18th May 2011 12:38am
p-trax
I had the same concern, hence checking it would function with a few tracks before the mass conversion Smile
As it worked initially i assumed, possibly incorrectly, that it would work with a large amount of data.
i will experiment with a 4GB key.
Thumbs Up Gerry
Post #64467 18th May 2011 8:33am
p-trax
Yup 4GB key works.
Wink
bit pathetic it cannot support a decent chunk of memory.................I wonder if this is also why it will not index my entire phone book? Gerry
Post #64476 18th May 2011 9:25am
There may be a LR update......
Post #64477 18th May 2011 9:28am
Ajay(UK)
p-trax wrote:
Yup 4GB key works.
Wink
Gerry, rather than waiting for an official answer from Land Rover perhaps you can experiment with 8gb , 16gb memory stick and tell us all which is the largest one that will actually work correctly Rolling with laughter
Post #64486 18th May 2011 10:13am
p-trax
not sure i have any 8 or 16's Gerry
Post #64488 18th May 2011 10:39am
p-trax
Ok. It will read a 16GB card with approx 12GB of data. These mp3 files are structured as per original post
Thumbs Up Gerry
Post #64501 18th May 2011 12:37pm
Also, try to keep the number of files in each folder to a minimum.
On my Audi (which can seriously only take a 4GB SD card) you can have either x files/folders in the root, or x folders with x files inside each one. The first option severely limits capacity, whilst the second one makes search,shuffle and playback more difficult vastly increases capacity.
Remember, computers see folders ( directories) as files.
So try something like 100 folders, each with 100 files in. However I suspect 32GB is just too big. You could try resizing the partition? .
Post #64608 18th May 2011 11:19pm
p-trax
Hey Joe, its working fine with same amount of data on the 16 as was originally on the 32.
so for now all is good Thumbs Up Gerry
Post #64669 19th May 2011 11:44am
Ajay(UK)
Hi Gerry, thank you for your experimental efforts Thumbs Up
I think, in conclusion we can say that the USB connection in a 2010MY onwards will work with a maximum 16GB memory stick Bow down
Cheers,
Post #64716 19th May 2011 12:32pm
I've had similar issues with large capacity SD cards of 32MB. They are supposed to work in my laptop and camcorder, but for some reason, even when they are empty, can't be read or identified. Discovery 4 HSE
Post #64733 19th May 2011 1:12pm
johnson1
My iPhone is 32GB and it reads all the files...99% of which is music...
Edit: Just dawned on me that the iPhone connector is a different port altogether...does seem odd though.
Post #64746 19th May 2011 2:05pm
