Home > Technical (L322) > 3.6 TDV8 Turbo Whistle? |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 |
I too get a kind of whistle on my TDV8 4.4 that is only noticeable in summer months when the windows are open, just after acceleration and you let off the gas pedal... Sound a bit like air brakes... big truck like... I kinda like it though... |
13th Jun 2021 5:00pm |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
sounds like a boost leak? RR Vogue 4.4 TDV8 - 11
13th Jun 2021 6:21pm |
RosieL322 Member Since: 20 May 2021 Location: County Durham Posts: 26 |
I was thinking that but no engine lights or faults displayed. Any way of checking if I have a leak? |
13th Jun 2021 7:09pm |
Someone a lot more knowledgeable than I will probably say something more clever but I would get it in for a high pressure smoke test?
13th Jun 2021 7:19pm |
RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 49 |
Other cars are known for having waste gate sealing issues, usually identified by reduced boost pressure. Is it possible to check the boost pressure against the ‘norm’ to eliminate this as an issue. The fix is adjustment of the waste gate actuator arm. 2011 TDV8 4.4 AB Bournville Brown |
24th Jun 2021 1:31pm |
I’ve had Rosie in to my local specialist for a code read. No loss of boost on the codes but a turbo actuator fault. They have lubed the actuator and reset the error but whistle still present. It’s not causing any issues so far, but would like to prevent anything serious if possible. She is back in for a full service and transmission flush in a couple of weeks so will see if they notice anything else. That’s you all for the suggestions. Mark |
24th Jun 2021 7:29pm |
