Home > Technical (L322) > Recommendations for a 4.4V8 Diesel Jump start pack please>
Page 2 of 3 <123>
TJH1985
Noco GB70 here, happily started our old 3.6 TDV8 when it was dead and that’s no small ask and it didn’t even flinch on the TD5 Defender / my Skoda Octavia! Great piece of kit Thumbs Up Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #595433 26th May 2021 9:17pm
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
mjdronfield wrote:
You sure it’s the battery and not the starter motor?
It’s going in today. I will ask them to check it
Post #595447 27th May 2021 6:29am
TeeMyob
Is it a common issue ?
Post #595449 27th May 2021 6:31am
TeeMyob
I’ve just read i post on here and suspect it’s the starter motor
Post #595451 27th May 2021 6:38am
mjdronfield
Mine is starting to do the same, even when battery is fully charged, as just been disconnected from a CTEK charger.
If the OE starters develop the issue there the connections in the selonoid get burnt on their faces (at least I think that’s what the issue is) I wonder if a non genuine starter is actually the way to go....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #595466 27th May 2021 9:42am
Philip
I wonder if there’s a resistance issue in the wiring or similar - the 3.6 doesn’t seem to suffer the same contact problems (I cleaned a lot of corrosion from the MEGA fuse of my L322 when it got a new battery - possibly the same at any other connections to the starter).
Post #595489 27th May 2021 12:22pm
TeeMyob
Went to JLR Dealer for the issue today. They said they could not find a fault.
See bottom line
Post #595570 27th May 2021 8:50pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Blimey Tee seeing the eye watering cost they want to charge for the faults they have allegedly found, I think the battery is the least of your worries.
Post #595572 27th May 2021 9:10pm
mjdronfield
Bit over £5k then 🤣
The jokers 🤣🤣
I’d say starter motor then, if battery is fine....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #595574 27th May 2021 9:47pm
Barmybrummie
And £87 to supply and fit 2 wiper blades? That really is taking the proverbial.
Post #595576 27th May 2021 9:54pm
mjdronfield
Oh come on... taking the proverbial would be another £114 Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #595577 27th May 2021 10:05pm
Greyskull
England 2009 Range Rover Vogue SE TDV8 Buckingham Blue
Diesel jump pack
Hi I’ve had same problem got a top don volcano 2000.. wouldn’t even turn car over then it started beeping and go flat 😡.so I’m installing a second battery in the right hand cubby storage I’ve got a wiring kit from LUXURY LAND ROVER UPGRADES HE HAS A HOW TO DO IT ON U TUBE ...he claps it down we’re I’ve fitted in to cubby storage box goes.on right hand side bit of a fiddle job but better than being stranded with a flat battery
Post #595594 28th May 2021 6:56am
TeeMyob
I've just got one of those delivered
Post #595692 28th May 2021 8:44pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
GB 150. Effortlessly started my 4.4.
Not needed since fitting twin batteries, new starter & FSR. Forty years of progress. 1972-2012
Post #596222 2nd Jun 2021 5:53pm
TeeMyob
Where did you compress the other battery into ?
Post #596263 3rd Jun 2021 8:14am
Page 2 of 3 <123>
