Home > Technical (L322) > Recommendations for a 4.4V8 Diesel Jump start pack please> |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 196 |
It’s going in today. I will ask them to check it |
27th May 2021 6:29am |
Is it a common issue ? |
27th May 2021 6:31am |
I’ve just read i post on here and suspect it’s the starter motor |
27th May 2021 6:38am |
Mine is starting to do the same, even when battery is fully charged, as just been disconnected from a CTEK charger.
27th May 2021 9:42am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
I wonder if there’s a resistance issue in the wiring or similar - the 3.6 doesn’t seem to suffer the same contact problems (I cleaned a lot of corrosion from the MEGA fuse of my L322 when it got a new battery - possibly the same at any other connections to the starter). |
27th May 2021 12:22pm |
Went to JLR Dealer for the issue today. They said they could not find a fault.
27th May 2021 8:50pm |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 653 |
Blimey Tee seeing the eye watering cost they want to charge for the faults they have allegedly found, I think the battery is the least of your worries. |
27th May 2021 9:10pm |
Bit over £5k then 🤣
27th May 2021 9:47pm |
And £87 to supply and fit 2 wiper blades? That really is taking the proverbial. |
27th May 2021 9:54pm |
Oh come on... taking the proverbial would be another £114 2011 Range Rover Vogue SE 4.4 TDV8
27th May 2021 10:05pm |
Greyskull Member Since: 13 Jun 2019 Location: Selby North Yorkshire Posts: 49 |
Hi I’ve had same problem got a top don volcano 2000.. wouldn’t even turn car over then it started beeping and go flat 😡.so I’m installing a second battery in the right hand cubby storage I’ve got a wiring kit from LUXURY LAND ROVER UPGRADES HE HAS A HOW TO DO IT ON U TUBE ...he claps it down we’re I’ve fitted in to cubby storage box goes.on right hand side bit of a fiddle job but better than being stranded with a flat battery |
28th May 2021 6:56am |
I've just got one of those delivered |
28th May 2021 8:44pm |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 |
GB 150. Effortlessly started my 4.4.
2nd Jun 2021 5:53pm |
Where did you compress the other battery into ? |
3rd Jun 2021 8:14am |
