![]() | Home > Maintenance & Mods (L322) > Mystery oil leak |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
Hi, do you have any picture of this leak? My 4.4 ajv8 has leak on indentical place, and I believe it is the upper oil pan, but it is so minor that I don't want to tackle with this, I just hope that it will not get any worse |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
I have not but that’s sort of what I was thinking and again it’s only the odd drip on the floor even thought there’s a thin coating.
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 ![]() ![]() |
A good while ago the front diff was replaced on my vehicle by a local indy. After about three months an occasional drip of oil would manifest itself on the ground under the front diff and tracking could be seen on the diff itself. So took it back to the indy who put it up on a ramp cleaned the diff up and investigated the origin. He found two of the engine sump bolts above the diff had a very slight amount of oil on them. As the oil pan is sealed with sealant and not a gasket he would not tighten them up, saying it may make it worse by displacing something. The bolts were cleaned up and I monitored the issue for some months. On the next service which I did, on a ramp, I removed all the undertrays and managed to locate the two offending bolts, both had oil on the heads. They are an absolute |
Did you torque to that or just nip them 1/4 turn? Current stable:
Just nipped them up. |
