![]() | Home > My Range Rover > Back to a Rangie (R666GRN) Questions! |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Just been out to mine to double check, my 2006 TD6 has Telephone / bluetooth function as per the 753 menu screen. I have no idea if this was standard, or an extra |
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 ![]() ![]() ![]() |
Ha!
The car got delivered to me last night. Very happy with it.
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Yep, that's the BT module sitting on the top of the stack in the left hand side of the boot. The one with the white optical cables going into it in the last picture
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
Don’t you have to pair your phone with it, before it will say a phone is connected?
Ok, I'll check it.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Search for the car on your phone. Not for your phone on the car. |
Just to come back to the key issue, how exactly can I change my key to the better flip key?
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 212 ![]() ![]() ![]() |
Turn bluetooth on your phonr find land rover key in 2121 |
If you go to total car check pay 2.00 for silver choice it will tell how many owners all the dates for numberplate changes and other plates it may have had its good info for £2.00 |
Yes, ensure key is 433mhz, cut blade, transfer transponder chip and synch key to car for central locking. If synch procedure fails, then you may need an out locksmith to delete previous key synch entries, to allow the system to synch your new keys. ( The key synch entry list may be full - so to speak ) You can do this yourself I was told, with a tool such as an XToolX100, but the prices start at around £160. |
Great thanks!
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 ![]() ![]() ![]() |
Great, thanks.
