![]() | Home > Technical (L322) > Starting to loose faith... steering rack issues |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 707 ![]() ![]() ![]() |
Changing the rack on the drive is doable.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8537 ![]() ![]() ![]() |
Do not use stop leak, it is a spirit that makes the seals expand by making them soft, if it works it will fail catastrophically after a short time, it will also ruin the pump...
Goodluck247 Member Since: 08 Jan 2021 Location: London Posts: 30 ![]() ![]() ![]() |
Thanks so much both, and great write up Pawl. Is there much difference between the 3.6TDV8 and a 2012 4.4TDV8?
I doubt the differences are significant.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1297 ![]() ![]() ![]() |
I had to have mine replaced under warranty, and cost an eye watering £3400 just because of a duff seal. Crazy. |
Thanks all. As to sourcing a replacement rack, I would be a bit wary of buying a second hand unit from a breakers online. I found a company that would recondition my existing one if I post it to them for 250 quid for a 3 day turn around time which didn't seem too bad. If not can you buy already reconditioned units anywhere? |
I agree ref buying second hand on-line.
Is there any difference between the 4.4TV8 rack and the 3.6? Just looking at these two ebay items, cant see any real difference other than the price?
Just because they look the same does not mean they are...
I've managed to finally source a reconditioned steering rack at a reasonable price. From speaking to a variety of different suppliers there is a difference between the 3.6TDV8 rack and the 4.4TDV8 one. If I can rope my friend in to assisting me this weekend then I'll do it then.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2685 ![]() ![]() ![]() |
Nothing wrong with recon racks, had one in my last one. Good Luck. |
