Home > Technical (L322) > Starting to loose faith... steering rack issues |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Changing the rack on the drive is doable.
8th Apr 2021 5:59pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8293 |
Do not use stop leak, it is a spirit that makes the seals expand by making them soft, if it works it will fail catastrophically after a short time, it will also ruin the pump...
8th Apr 2021 6:07pm |
Goodluck247 Member Since: 08 Jan 2021 Location: London Posts: 30 |
Thanks so much both, and great write up Pawl. Is there much difference between the 3.6TDV8 and a 2012 4.4TDV8?
8th Apr 2021 7:23pm |
I doubt the differences are significant.
8th Apr 2021 7:26pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1222 |
I had to have mine replaced under warranty, and cost an eye watering £3400 just because of a duff seal. Crazy. |
8th Apr 2021 10:16pm |
Thanks all. As to sourcing a replacement rack, I would be a bit wary of buying a second hand unit from a breakers online. I found a company that would recondition my existing one if I post it to them for 250 quid for a 3 day turn around time which didn't seem too bad. If not can you buy already reconditioned units anywhere? |
9th Apr 2021 7:55am |
I agree ref buying second hand on-line.
9th Apr 2021 9:38am |
Is there any difference between the 4.4TV8 rack and the 3.6? Just looking at these two ebay items, cant see any real difference other than the price?
9th Apr 2021 4:15pm |
Just because they look the same does not mean they are...
9th Apr 2021 4:22pm |
I've managed to finally source a reconditioned steering rack at a reasonable price. From speaking to a variety of different suppliers there is a difference between the 3.6TDV8 rack and the 4.4TDV8 one. If I can rope my friend in to assisting me this weekend then I'll do it then.
26th Apr 2021 12:56pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2656 |
Nothing wrong with recon racks, had one in my last one. Good Luck. |
26th Apr 2021 1:16pm |
