Home > Maintenance & Mods (L322) > never never again!
Chris1573
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
never never again!
So decided to tackle the rear end and all the surface rust to try and prevent it getting too bad. I think this RR may have seen a couple of boat launches at some point as there is a fair bit of surface rust. So got the wire brushes out and spent several hours getting the worst of the flaky stuff off. In my wisdom I thought I would go with POR-15 to paint over the rusty bits. What a fcking horrible nightmare of a job. 2 hours under the car trying to get into all the nooks and crannys. My hair is full of Por-15 and the postman was Censored himself as its all over my face as well. (and takes two weeks to come off apparently).
POR-15 might be good stuff but not to try and apply under the car. Coating a rusty part on your workbench maybe. But not what i'm trying to do with it.
Worst bit is I have done one coat and in 2 hours i'm back out there for the second one... Big Cry Big Cry Big Cry L322 2007 TDV8 3.6
Post #587771 17th Mar 2021 3:10pm
Rolling with laughter
Post #587820 17th Mar 2021 9:37pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hahaha
Be careful though as black facing isn’t acceptable anymore :p
Post #587830 17th Mar 2021 10:29pm
V8_Disco
Not minded to do mine while your at it? I would happily drive it down to you Wink
Post #587857 18th Mar 2021 9:28am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I hate por-15. Everyone says it's good but when I used it I just found it to be too hard to use and very sensitive to what it goes over. And yes it's hard to get off skin!!
Post #587872 18th Mar 2021 11:52am
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
I used Por 15 on my disco a few years ago, would never use it again, it is sensitive to what it is painted on (apart from skin which it really sticks to!). I used Hammarite all the time now, cheaper and seems just as good at keeping the rust away. L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Sunbeam S7 deluxe (in bits)
Sunbeam S8 (restoring)
Post #587876 18th Mar 2021 12:28pm
bishbosh10
In my experience POR15 sticks really well to surface rust but just comes off in sheets if applied to sound metal.... go figure.... Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #587912 18th Mar 2021 5:04pm
mark towill
Canada 2008 Range Rover HSE 4.4 V8 Stornoway Grey
I used POR15 on my rusted area hidden by the sill [ normal place where it lurks]. You must use a degreaser/cleaner, then a metal etcher then the POR15. I did two coats and put fiberglass coated with POR15 in the rust-out areas. It worked very well to protect the jacking sites. I also used it to protect the compressed air tank. I am getting ready to protect the rear suspension bits. You need a hazmat suit almost. It is brutal if you get it on your skin Censored
Post #587968 19th Mar 2021 2:31am
Chris1573
Yes this is what they say, if you want to apply to a smooth surface it needs to be "keyed" with some sandpaper. It likes a rough surface to grip hold of. Hence why it likes rust...! L322 2007 TDV8 3.6
Post #587973 19th Mar 2021 8:05am
Chris1573
Ha Ha.... NO ! L322 2007 TDV8 3.6
Post #587974 19th Mar 2021 8:06am
mark towill
It is ok I will come to your place! I need parts and information for my 2007 DB9 which I will be acquiring in less than a month Very Happy
Post #588012 19th Mar 2021 1:34pm
V8_Disco
Chris1573 wrote:
Ha Ha.... NO !
Worth an ask ...
Post #588021 19th Mar 2021 2:46pm
Chris1573
Mr. Green L322 2007 TDV8 3.6
Post #588099 20th Mar 2021 7:07am
