Home > Maintenance & Mods (L322) > never never again! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 |
17th Mar 2021 8:37pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Hahaha
17th Mar 2021 9:29pm |
V8_Disco Member Since: 24 Dec 2020 Location: Yorkshire Posts: 101 |
Not minded to do mine while your at it? I would happily drive it down to you |
18th Mar 2021 8:28am |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I hate por-15. Everyone says it's good but when I used it I just found it to be too hard to use and very sensitive to what it goes over. And yes it's hard to get off skin!! |
18th Mar 2021 10:52am |
Rog21 Member Since: 09 Nov 2018 Location: Havant Posts: 62 |
I used Por 15 on my disco a few years ago, would never use it again, it is sensitive to what it is painted on (apart from skin which it really sticks to!). I used Hammarite all the time now, cheaper and seems just as good at keeping the rust away. L322 4,4 TDV8
18th Mar 2021 11:28am |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
In my experience POR15 sticks really well to surface rust but just comes off in sheets if applied to sound metal.... go figure.... Bish.
18th Mar 2021 4:04pm |
mark towill Member Since: 27 Aug 2020 Location: calgary Posts: 19 |
I used POR15 on my rusted area hidden by the sill [ normal place where it lurks]. You must use a degreaser/cleaner, then a metal etcher then the POR15. I did two coats and put fiberglass coated with POR15 in the rust-out areas. It worked very well to protect the jacking sites. I also used it to protect the compressed air tank. I am getting ready to protect the rear suspension bits. You need a hazmat suit almost. It is brutal if you get it on your skin |
19th Mar 2021 1:31am |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 |
Yes this is what they say, if you want to apply to a smooth surface it needs to be "keyed" with some sandpaper. It likes a rough surface to grip hold of. Hence why it likes rust...! L322 2007 TDV8 3.6 |
19th Mar 2021 7:05am |
Ha Ha.... NO ! L322 2007 TDV8 3.6 |
19th Mar 2021 7:06am |
It is ok I will come to your place! I need parts and information for my 2007 DB9 which I will be acquiring in less than a month |
19th Mar 2021 12:34pm |
Worth an ask ... |
19th Mar 2021 1:46pm |
20th Mar 2021 6:07am |
