Home > Technical (L322) > Boot accessory socket - ignition only? |
Grizzly_Adams Member Since: 11 Dec 2017 Location: Brisbane Posts: 36 |
Hi All,
10th Mar 2021 1:07am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 518 |
See https://www.fullfatrr.com/forum/post512892.html#512892 2016 Skoda Octavia VRS Estate
10th Mar 2021 7:30am |
Well that's pretty sucky if true, I specifically looked in the owners manual before using it and ensured it said 'permanently live' - bit of a discrepancy then between the owners manual and reality |
10th Mar 2021 7:59am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
It’s definitely true mate. I had a 2003 TD6 and they were always on. Got a 2011 TDV8 and then a pretty expensive 12v cooler box..... and it just kept powering off.
10th Mar 2021 9:27am |
Here was my discussion thread at the time, also showing the manual to be incorrect....
10th Mar 2021 9:32am |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
Is there a way to re position a fuse so it can be changed to permanent?
10th Mar 2021 2:07pm |
On another forum, someone suggested "You can replace the relay with a short jumper lead fitted with spade terminals to make it permanently powered" which is an interesting idea - now just need to find the relay |
11th Mar 2021 3:24am |
Thanks! What a PiTA, but thanks for the confirmation |
11th Mar 2021 3:27am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2495 |
11th Mar 2021 7:10am |
