![]() | Home > Technical (L322) > Boot accessory socket - ignition only? |
Grizzly_Adams Member Since: 11 Dec 2017 Location: Brisbane Posts: 36 ![]() ![]() ![]() |
Hi All,
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 528 ![]() ![]() ![]() |
See https://www.fullfatrr.com/forum/post512892.html#512892 2016 Skoda Octavia VRS Estate
Well that's pretty sucky if true, I specifically looked in the owners manual before using it and ensured it said 'permanently live' - bit of a discrepancy then between the owners manual and reality |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
It’s definitely true mate. I had a 2003 TD6 and they were always on. Got a 2011 TDV8 and then a pretty expensive 12v cooler box..... and it just kept powering off.
Here was my discussion thread at the time, also showing the manual to be incorrect....
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Is there a way to re position a fuse so it can be changed to permanent?
On another forum, someone suggested "You can replace the relay with a short jumper lead fitted with spade terminals to make it permanently powered" which is an interesting idea - now just need to find the relay |
Thanks! What a ![]() ![]() |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2655 ![]() ![]() |
