Home > Technical (L322) > Boot accessory socket - ignition only?
Grizzly_Adams
Australia 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi All,
I was away camping / 4wd'ing over the weekend and found out my camper trailer battery had failed. No problems, I'll connect my portable fridge to the "always on 12v accessory socket in the boot" (according to the owners manual).
Imagine my surprise the next morning to find that the socket loses power with the ignition Surprised
I believe this socket is supposed to be always on? Can others confirm this please?
For reference, this is a 2010 L322 5.0sc Autobiography.
I've already had to 'repair' the rear trailer wiring after a previous owner had hacked it up, so I'm assuming they've done something with 12v socket also Sad
Thanks!
Post #586891 10th Mar 2021 1:07am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
See https://www.fullfatrr.com/forum/post512892.html#512892 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #586898 10th Mar 2021 7:30am
Grizzly_Adams
Well that's pretty sucky if true, I specifically looked in the owners manual before using it and ensured it said 'permanently live' - bit of a discrepancy then between the owners manual and reality Sad
Post #586899 10th Mar 2021 7:59am
mjdronfield
It’s definitely true mate. I had a 2003 TD6 and they were always on. Got a 2011 TDV8 and then a pretty expensive 12v cooler box..... and it just kept powering off.
I did a bit of research to find that the later facelift cars power the sockets down.
I’m not sure if you can do something in the fuse box to keep them on....
Could be in the thread linked to above.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #586910 10th Mar 2021 9:27am
mjdronfield
Here was my discussion thread at the time, also showing the manual to be incorrect....
https://www.fullfatrr.com/forum/topic37705.html?highlight=socket
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #586911 10th Mar 2021 9:32am
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Is there a way to re position a fuse so it can be changed to permanent?
I have a golf & moved a fuse so it swapped to permanently live.
pic is the VW way, wonder if it’s possible on RR??
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #586945 10th Mar 2021 2:07pm
Grizzly_Adams
On another forum, someone suggested "You can replace the relay with a short jumper lead fitted with spade terminals to make it permanently powered" which is an interesting idea - now just need to find the relay Surprised
Post #586992 11th Mar 2021 3:24am
Grizzly_Adams
Thanks! What a Censored PiTA, but thanks for the confirmation Smile
Post #586993 11th Mar 2021 3:27am
GraemeS
https://www.fullfatrr.com/gallery/albums/u...kets~0.pdf
Post #586997 11th Mar 2021 7:10am
