Home > My Range Rover > My Stornoway Grey Vogue SE
Page 4 of 7 <1234567>
Jayk69
dont over think the disc and pads just make sure you get a reputable brand they will be fine, if they are LR branded then you will be paying over the odds for no reason other than the kudos of saying you have original parts.
the calipers should look awesome Thumbs Up when done 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #590742 9th Apr 2021 6:45pm
DaleL322
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
I’ll be going with Ferodo pads and possibly Ferodo discs too.. although I am considering some mtec discs if I fancy something different 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
https://www.fullfatrr.com/forum/topic58777.html
Post #590744 9th Apr 2021 7:58pm
DaleL322
Just received the 4.4 TDV8 rear brake callipers and pad carriers to upgrade at the same time as the fronts
They have come off a low mileage breaker and are both the OE Land Rover TRW callipers in very good condition
Looking forward to stripping these down at the same time as the front callipers and giving them all a freshen up Cool
Post #591316 15th Apr 2021 3:17pm
DaleL322
Todays job is trying to pin point an oil leak I've got coming from above the front diff.. we're suspecting transmission cooler pipes so lets see how we get on
Post #597675 16th Jun 2021 8:59am
DaleL322
On closer inspection and after removing the front prop and the N/S catalytic convertor we have found the front pinion input shaft to be leaking from the splines. New seal and gaskets ordered from Land Rover and with the use of the workshop manual off the Wiki page hopefully should have it sorted by tomorrow to retest Thumbs Up
Post #597703 16th Jun 2021 1:49pm
DaleL322
With a bit of time to kill while waiting for parts, I have repaired my rear washer which wasn't working, simply needed a new one-way valve
While I had the spoiler off I set about replacing the high level brake light with a tinted one I've had for a while too, actually looks pretty nice to be fair Cool
Post #597713 16th Jun 2021 4:23pm
DaleL322
I also thought while I have it on the ramp it'd pay to check the aircon, while it still works it's not been 100% perfect recently
Pulled out 470g of gas and the required 700g going back in now.. another job done Very Happy
Post #597717 16th Jun 2021 4:49pm
Jayk69
all good stuff keep the updates coming Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #597824 17th Jun 2021 4:55pm
DaleL322
Thank you Jayk69 Very Happy
Last night I rubbed down and sprayed the back box with some matt black VHT I had lying around, as it was starting to look a little tatty. Apologies that this isn't the best picture, but you get the idea Thumbs Up
Post #597911 18th Jun 2021 11:58am
DaleL322
This has been bugging me for a while (Ever since I was educated that there was supposed to be a cover over the switch Laughing )
Post #598375 22nd Jun 2021 2:41pm
DaleL322
I decided to strip the dash down to remove the glove box trim at lunch today
Old trim removed and my new Piano Black trim ready to go on Cool
Post #598377 22nd Jun 2021 2:45pm
Looking good... Thumbs Up Pete
Post #598379 22nd Jun 2021 2:58pm
DaleL322
Cheers Pete Very Happy
I know this wont be to everyone's taste and I admit it's pretty nerdy.. but I really do like my new personalised dash badge Rolling Eyes
Post #598441 23rd Jun 2021 9:15am
DaleL322
After a lot of hard work and effort I am so happy to finally have one of my Piano Black Dash Trims fitted to my car
I'm so happy with how this has turned out Very Happy
Post #598547 24th Jun 2021 8:29am
DaleL322
After seeing a few other members on here with them, I treated myself to some Auto Clover Wind Deflectors for my Birthday earlier in the month.
I have to say I am seriously impressed with the quality and the fit, and I especially like the sleek 6 piece design
Tasteful and subtle I think Cool
Post #598548 24th Jun 2021 8:34am
