![]() | Home > My Range Rover > My Stornoway Grey Vogue SE |
DaleL322 Member Since: 04 Mar 2021 Location: Stamford Posts: 176 ![]() ![]() ![]() |
I’ll be going with Ferodo pads and possibly Ferodo discs too.. although I am considering some mtec discs if I fancy something different 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
Just received the 4.4 TDV8 rear brake callipers and pad carriers to upgrade at the same time as the fronts
https://www.fullfatrr.com/forum/topic58777.html |
Todays job is trying to pin point an oil leak I've got coming from above the front diff.. we're suspecting transmission cooler pipes so lets see how we get on
On closer inspection and after removing the front prop and the N/S catalytic convertor we have found the front pinion input shaft to be leaking from the splines. New seal and gaskets ordered from Land Rover and with the use of the workshop manual off the Wiki page hopefully should have it sorted by tomorrow to retest
With a bit of time to kill while waiting for parts, I have repaired my rear washer which wasn't working, simply needed a new one-way valve
While I had the spoiler off I set about replacing the high level brake light with a tinted one I've had for a while too, actually looks pretty nice to be fair ![]()
I also thought while I have it on the ramp it'd pay to check the aircon, while it still works it's not been 100% perfect recently
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
all good stuff keep the updates coming |
Thank you Jayk69 |
This has been bugging me for a while (Ever since I was educated that there was supposed to be a cover over the switch
I decided to strip the dash down to remove the glove box trim at lunch today
Old trim removed and my new Piano Black trim ready to go on ![]()
![]() https://www.fullfatrr.com/forum/topic58777.html |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Looking good... |
Cheers Pete
After a lot of hard work and effort I am so happy to finally have one of my Piano Black Dash Trims fitted to my car
After seeing a few other members on here with them, I treated myself to some Auto Clover Wind Deflectors for my Birthday earlier in the month.
