Home > My Range Rover > My Stornoway Grey Vogue SE |
DaleL322 Member Since: 04 Mar 2021 Location: Stamford Posts: 176 |
I’ll be going with Ferodo pads and possibly Ferodo discs too.. although I am considering some mtec discs if I fancy something different 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
9th Apr 2021 6:58pm |
Just received the 4.4 TDV8 rear brake callipers and pad carriers to upgrade at the same time as the fronts
15th Apr 2021 2:17pm |
Todays job is trying to pin point an oil leak I've got coming from above the front diff.. we're suspecting transmission cooler pipes so lets see how we get on
16th Jun 2021 7:59am |
On closer inspection and after removing the front prop and the N/S catalytic convertor we have found the front pinion input shaft to be leaking from the splines. New seal and gaskets ordered from Land Rover and with the use of the workshop manual off the Wiki page hopefully should have it sorted by tomorrow to retest
16th Jun 2021 12:49pm |
With a bit of time to kill while waiting for parts, I have repaired my rear washer which wasn't working, simply needed a new one-way valve
16th Jun 2021 3:23pm |
I also thought while I have it on the ramp it'd pay to check the aircon, while it still works it's not been 100% perfect recently
16th Jun 2021 3:49pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
all good stuff keep the updates coming 2012 Vogue 4.4 TDV8 - Current
17th Jun 2021 3:55pm |
Thank you Jayk69
18th Jun 2021 10:58am |
This has been bugging me for a while (Ever since I was educated that there was supposed to be a cover over the switch )
22nd Jun 2021 1:41pm |
I decided to strip the dash down to remove the glove box trim at lunch today
22nd Jun 2021 1:45pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8313 |
Looking good... Pete
22nd Jun 2021 1:58pm |
Cheers Pete
23rd Jun 2021 8:15am |
After a lot of hard work and effort I am so happy to finally have one of my Piano Black Dash Trims fitted to my car
24th Jun 2021 7:29am |
After seeing a few other members on here with them, I treated myself to some Auto Clover Wind Deflectors for my Birthday earlier in the month.
24th Jun 2021 7:34am |
