![]() | Home > Maintenance & Mods (L322) > Lanoguard under body rust proofing - I’m a convert!!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
Funnily enough I was only reading about that the other day, Dinotrol has always been my choice but very interested to hear what you think of Lanoguard... Pete
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
This chap applied it to his Defender and compared to Ditrinol, waxoyl and the like it looked simple..
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 490 ![]() ![]() |
I know Lanoguard is highly regarded for it's rust prevention / self healing properties, but my understanding is it needs to be re-applied at least every year. |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 ![]() ![]() ![]() |
I have done my 2010 L322 over a year ago and still looking good and haven’t need to renew it yet but it’s so simple it wouldn’t bother me doing every year |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4320 ![]() ![]() ![]() |
Darren - did you use Lanoguard on yours then? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Yes used Lanoguard used about 3.5l underneath and while I was at it took plastic wheel arch liners out and side trims and also did under there |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
ive just bought some as well will be giving mine a good coating shortly. L322 2007 TDV8 3.6 |
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
Yes seen this on you tube, as mentioned I understood it's life span short before needing topping up so that and price put me off. I paid £28.00 for 5L of waxoyl and that will do everything and last a few years. Lanoguard does look less messy so will be interested in users comments. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
V8_Disco Member Since: 24 Dec 2020 Location: Yorkshire Posts: 101 ![]() ![]() |
I am probably going this way as well, how bad are the plastic trims to get on and off will I need some clips etc ? |
I broke 3 trim clips on the first side and none on the other ( sill trim ) |
I managed to get both sill covers off without breaking any, first time that's happened. I do have a plastic fittings kit so did have some spares if needed.
Thanks are they anything special or will my mixed box (bought for repairing a 5 series) be enough ? |
Mine was just a mixed box of fasteners bought off EBay and they were in there. Picture below of what they are like, just check your kit.
Perfect thank you |
