![]() | Home > Maintenance & Mods (L322) > Lanoguard under body rust proofing - I’m a convert!!! |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
jim i am going to do this in the summer.
Jases4x4 Member Since: 29 Jan 2021 Location: Yorkshire Posts: 10 ![]() ![]() ![]() |
Im going to do this soon it was either this or dinitrol as this last longer im told but maybe alittle messier spraying that, I wonder if using some sort of degreaser would be best to spray on first or just a blast water from the jet wash, did you clean it first with anything? |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
I sprayed my rear box with Rustoleum Matt black spray paint. I just jet washed it and let it dry first.
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
Good pics, Looks a good job and sounds easier and cleaner than Waxoyl. Might give it a go when I get round to it! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
V8_Disco Member Since: 24 Dec 2020 Location: Yorkshire Posts: 101 ![]() ![]() |
Jim
I decided not to go for the tub of grease as I wanted to be able to see what is going on with the chassis in the future. The spray is really easy and clean and appears to coat and creep very well.
Thanks - i will be placing an order tomorrow for think |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 ![]() ![]() ![]() |
I bet that it was simple to spray the chassis with your car in its roof.......😅
Yes made it so much easier when my 12 year old has finished home schooling I will ask her to turn them around |
