![]() | Home > Maintenance & Mods (L405) > L405 jack adaptor |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Not heard of an adapter for the L405.
LT Member Since: 13 Mar 2017 Location: South West Posts: 414 ![]() ![]() ![]() |
Just reviving this on the off chance that someone has found an adaptor for the L405. |
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 234 ![]() ![]() ![]() |
following. |
Does the jacking point protrude ? With deployable steps, there's a bit that hangs down which is the new jamming point as the old one is covered by the step
Yes, the jacking points do protrude (no side steps) but not as prominently as in your photo.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
A block of wood works fine. I haven't seen any specific adapters. Kev
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2051 ![]() ![]() |
I have asked the same, but never got an answer ![]() |
Thread revival, just on the off chance. |
discovery Member Since: 29 Jan 2024 Location: hampshire Posts: 14 ![]() ![]() |
Hi LT, I too am long time disco owner with adapter. On disco3 site I am known as Stick, we have exchanged the odd message over the years. I am looking at getting ffrr (with some sadness). What have you ended up using for an adapter? |
RDR Member Since: 05 Sep 2014 Location: Derbyshire Posts: 278 ![]() ![]() |
i think you just need a standard V adapter for the L405?
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1683 ![]() ![]() ![]() |
There are hockey-puck heavy rubber adapters about 4” diameter on eBay with a slot cut in to fit the rib in the RR deplorable step jacking points.
THESE:
Thanks, ordered |
Excellent piece of kit - 14 years of good use. ![]() |
