Home > Maintenance & Mods (L405) > L405 jack adaptor
LT
L405 jack adaptor
I have both a Clarke trolley jack and also a Mercedes Sprinter bottle jack with adaptors for the Discovery3/4.
Can I buy a suitable adaptor for the L405?
A forum search only revealed one L405 thread, which has a link but is no longer working. Sad
Post #584840 22nd Feb 2021 5:56pm
Not heard of an adapter for the L405.
If you have deployable steps, the jacking point is on those & quite low - works well with a trolly jack, but I haven't found a bottle jack to fit.
Without the steps the jacking post is higher - but that's about all I know as I have steps....
Post #584919 23rd Feb 2021 10:25am
LT
Just reviving this on the off chance that someone has found an adaptor for the L405.
Post #596648 6th Jun 2021 7:50pm
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
following.
Post #598738 25th Jun 2021 3:02pm
Does the jacking point protrude ? With deployable steps, there's a bit that hangs down which is the new jamming point as the old one is covered by the step
This works great with a trolley jack with no other pad, but not so good for a bottle as it would need to be quite short but with a really high lift and those seem to be very expensive.
I did get as far as buying a bottle jack topper thing from eBay, but then realised I had no idea how I would attach it Confused it's 4cm in diameter and at least it was only a fiver so not too much buyers remorse
Post #598742 25th Jun 2021 3:30pm
LT
Yes, the jacking points do protrude (no side steps) but not as prominently as in your photo.
I have both a trolley jack and bottle jack, I'm more keen for an adapter pad for the trolley jack though.
Post #598756 25th Jun 2021 4:36pm
knwatkins
A block of wood works fine. I haven't seen any specific adapters. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #598774 25th Jun 2021 6:15pm
nbunney
I have asked the same, but never got an answer Sad
Post #598965 28th Jun 2021 7:20am
LT
Thread revival, just on the off chance. Smile
Post #611859 6th Nov 2021 10:05pm
discovery
Hi LT, I too am long time disco owner with adapter. On disco3 site I am known as Stick, we have exchanged the odd message over the years. I am looking at getting ffrr (with some sadness). What have you ended up using for an adapter?
Post #684582 2nd Feb 2024 7:54am
RDR
i think you just need a standard V adapter for the L405?
its not like the D3/4 with the holes, I used to make and sell the metal adapters for forum members over on the Disco3 sister site Very Happy MY23 PHEV HSE
MY19 Disco 5 HSE - gone
My16 Disco 4 HSE LUXURY - gone
My12 Disco 4 HSE - gone
MY05 Disco 3 S - gone but not forgotten
Post #684591 2nd Feb 2024 9:54am
Gremlin500
There are hockey-puck heavy rubber adapters about 4” diameter on eBay with a slot cut in to fit the rib in the RR deplorable step jacking points.
Mine are a bit chewed, must get a couple more…… “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #684609 2nd Feb 2024 12:31pm
Gremlin500
THESE:
https://www.ebay.co.uk/itm/274452706791?mk...media=COPY
Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #684610 2nd Feb 2024 12:34pm
discovery
Thanks, ordered
Post #684628 2nd Feb 2024 5:16pm
discovery
Excellent piece of kit - 14 years of good use. Bow down
Post #684629 2nd Feb 2024 5:18pm
