Home > Technical (L322) > TD6 Air Suspension Fault |
nar53 Member Since: 04 Nov 2015 Location: Le Mans Posts: 120 |
Hello All
19th Feb 2021 4:06pm |
Hi, No I haven't checked that but until these last few days it's been running at normal ride height. I'll check it out though. Thanks. |
19th Feb 2021 5:41pm |
Nobody else with any idea whats going on here?
20th Feb 2021 11:55am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8230 |
Download the workshop manual from the wiki (link top right)
20th Feb 2021 2:01pm |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 |
"... jack the fatty up and the sensor wipes across parts not used often, this can cause them to read incorrectly..."
20th Feb 2021 5:54pm |
Oh right, well I know they don't like being messed with, had several fail on my old fatty when they had had a workout, I presumed the why... obviously something else upsets them.. Pete
20th Feb 2021 6:06pm |
Ian G Member Since: 07 Sep 2020 Location: Liverpool Posts: 35 |
Can you get actual fault codes from the diag? Apologies if I've missed it but that's only the dash display or using the tool to clear which I wouldn't imagine is the limit of information available. |
20th Feb 2021 10:19pm |
The IID gives a lot of information as well as fault codes... Pete
21st Feb 2021 12:18am |
Thank you everyone for your input. I'm pretty sure the fault is related to the work I did as interment faults & warning started showing up after I did the work.
22nd Feb 2021 12:31pm |
