![]() | Home > Technical (L322) > TD6 Air Suspension Fault |
nar53 Member Since: 05 Nov 2015 Location: Le Mans Posts: 120 ![]() ![]() ![]() |
Hello All
Hi, No I haven't checked that but until these last few days it's been running at normal ride height. I'll check it out though. Thanks. |
Nobody else with any idea whats going on here?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
Download the workshop manual from the wiki (link top right)
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 129 ![]() ![]() ![]() |
"... jack the fatty up and the sensor wipes across parts not used often, this can cause them to read incorrectly..."
Oh right, well I know they don't like being messed with, had several fail on my old fatty when they had had a workout, I presumed the why... obviously something else upsets them.. |
Ian G Member Since: 07 Sep 2020 Location: Liverpool Posts: 35 ![]() ![]() ![]() |
Can you get actual fault codes from the diag? Apologies if I've missed it but that's only the dash display or using the tool to clear which I wouldn't imagine is the limit of information available. |
The IID gives a lot of information as well as fault codes... Pete
Thank you everyone for your input. I'm pretty sure the fault is related to the work I did as interment faults & warning started showing up after I did the work.
