Home > Technical (L322) > TDV8 4.4 engine rebuild, preventative mod info ? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
Just an idea,..If it’s a very late L322 maybe it was seen as a prototype for the L405 ?.
11th Mar 2021 9:38pm |
Autobiographyblack Member Since: 01 Feb 2021 Location: Shropshire Posts: 33 |
Its a sept 2010 build, so first of the 4.4’s |
11th Mar 2021 9:39pm |
It must have been modified at some time then.
11th Mar 2021 9:49pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
An early vehicle which could easily have been one of the earliest to suffer the smoke problem, possibly after already having had the secondary turbo replaced but the problem persisted. An 04/14 build L405 on this forum had a factory-fitted slightly different twin drain but L405s started with the same single drain as the L322. |
11th Mar 2021 10:45pm |
Im struggling to find oil cooler seals, LR are saying on back order with no ETA.....
12th Mar 2021 12:09pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
12th Mar 2021 12:21pm |
My friend is an old school mechanic and very much into doing things right, hes just called saying hes disgusted with how the oilcooler sits on the sandwich plate to the block, he said the cast of the sandwich plate is disgraceful and no wonder they all leak, he said, when you place the cooler on unbolted it rocks and in places has 30 thou gap, pulls down with bolts but he finds that very poor engineering. |
12th Mar 2021 1:46pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7799 |
And probably not helped either, by the constant heating up and cooling down.....
12th Mar 2021 4:15pm |
I said that but his response was if thats the case its bad design, either way a poor show |
12th Mar 2021 4:20pm |
Oh yes, for sure. It’s such a common issue now. The specialist that did mine about 5 years ago, hadn’t done many oil coolers. Within a year they had done over a dozen....
12th Mar 2021 5:16pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
this is why i replaced the whole cooler!! have to say when i put the new one on it did not rock. but equally i did not have the engine on a stand either. perhaps that is why they have the rubber compression gaskets i did find them odd given the bif temp swings they go through.
15th Mar 2021 8:02pm |
Mine certainly didn't rock when I fitted new gaskets. I would not have proceeded with such a condition. |
15th Mar 2021 8:05pm |
He did say it seems to pull dow straight once tightened down |
15th Mar 2021 8:08pm |
After some thought and considering GraemeS comment ive now decided to order a new cooler to be safe. |
16th Mar 2021 5:22pm |
