![]() | Home > Technical (L405) > How do I turn this off? |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
on the l322 this comes on when using any of the special programs its turned on/off in the appearance settings, could be the same on yours maybe 2012 Range Rover Westminster 4.4 TDV8
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2664 ![]() ![]() |
Yup, special programmes are switched on with the rotary dial beside gear selector |
Gazm007 Member Since: 22 May 2019 Location: Surrey Posts: 37 ![]() ![]() ![]() |
you may have accidently pressed the round dial (for terrain) beside the gear selector - once it pops up you can rotate it. try pushing it back down. |
goddo Member Since: 27 Oct 2020 Location: south Posts: 83 ![]() ![]() |
Thanks for the replies.
So, some feed back.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
Could it have come on automatically due to the snow? It is switched to Auto |
Not sure Craig, but to be honest what snow we have had has only been light and I haven't been using the car to get any
Final update:
