Home > Technical (L405) > How do I turn this off?
goddo
2014 TDV6 L405;
All of a sudden, I have got a diagram showing on my dash which is a plan view of the four wheels and when I turn the steering, the front wheels on the diagram rotate. I don't recall altering anything to make this diagram appear but would prefer that it is turned off. I looked through the owners manual this afternoon and can find no mention of it.
Any help gratefully received. Thanks.
Post #583157 10th Feb 2021 6:47pm
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
on the l322 this comes on when using any of the special programs its turned on/off in the appearance settings, could be the same on yours maybe 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #583160 10th Feb 2021 6:55pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Yup, special programmes are switched on with the rotary dial beside gear selector
Post #583161 10th Feb 2021 6:57pm
Gazm007
United Kingdom 2013 Range Rover Autobiography SDV8 Havana
Re: How do I turn this off?
you may have accidently pressed the round dial (for terrain) beside the gear selector - once it pops up you can rotate it. try pushing it back down.
Post #583209 11th Feb 2021 8:02am
goddo
Thanks for the replies.
It's snowing a little and bl**dy cold outside at the moment so I'll check it later.
I'll report back. Thanks again.
Post #583226 11th Feb 2021 10:02am
goddo
So, some feed back.
The terrain button by the gear shift knob was showing "Auto" but I raised the knob and cycled through the alternatives until special programmes showed "Off" on the dash.
Locked the knob down and the symbol seems to have disappeared from the dash display.
I haven't been out anywhere in the car so fingers crossed.
Thanks agin for your advice.
Post #583266 11th Feb 2021 2:37pm
Could it have come on automatically due to the snow? It is switched to Auto Thumbs Up
Post #583321 12th Feb 2021 12:47am
goddo
Not sure Craig, but to be honest what snow we have had has only been light and I haven't been using the car to get any
snow caked into the steering/transmission anyway. Very odd.
I will be using the car in a few days time so will report back if the problem is cured or not.
It still seems strange to say that "I will be using the car in a few days time"...... especially when, in the past, I had not even given car usage a thought, just did it.
Post #583352 12th Feb 2021 10:58am
goddo
Final update:
I used the car this morning and the diagram on the dash has now gone.
Thanks again.
Post #583430 12th Feb 2021 4:07pm
