Home > Maintenance & Mods (L322) > td6 top hose possibly numpty question of the day.
12ty
Hi Sorry in advance if this is the Numpty question of the day.
I am trying to change my top hose, I have removed the clip from the radiator and removed the connector no problem
I have removed the pin from the engine side but will this little fecker come off.
It looks like the stubb from the the engine is plastic so I have been very careful to not exert side ways movement. I can get it to come forward approx 1mm and I have been spraying penetrating oil in case the o ring is dry.
It feels as though I have another clip I have not released yet. Does it pull straight off or does it have to rotate 90 degrees before being removed.
Thanks in Advance
Post #582499 5th Feb 2021 3:07pm
stuart_2006
Its the same type of connector as the radiator end - but apparently the internal O-ring sticks itself to the outlet pipe and so is difficult to remove - I had the same problem trying to remove that connection when doing the thermostat mod. The connector would move a millimetre or two but that was it. It's easy to cut the retaining ring round the hose off with a Dremel and replace with a Jubilee clip (so replace the hose but not that end connector).
Post #582513 5th Feb 2021 7:00pm
12ty
Hi Thanks for the reply, I thought I was going daft or something. Thumbs Up
It is the thermostat mod that I am doing. I am not going to attempt today now as I have to collect my dremel and if I dont finish today I dont fancy doing it in the snow tomorrow.
Probably next weekend now.
Did you have the issue with the temp gauge between 10 & 11 o'clock?
I am looking forward to having a toastier car a little bit quicker in the mornings.
Post #582582 6th Feb 2021 2:52pm
stuart_2006
Yep, I was doing the thermostat mod as well. Before, the needle would just get a tiny bit past the blue. Now sits at 12 o'clock. Wink
Post #582612 6th Feb 2021 7:11pm
