![]() | Home > Maintenance & Mods (L322) > td6 top hose possibly numpty question of the day. |
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 129 ![]() ![]() ![]() |
Its the same type of connector as the radiator end - but apparently the internal O-ring sticks itself to the outlet pipe and so is difficult to remove - I had the same problem trying to remove that connection when doing the thermostat mod. The connector would move a millimetre or two but that was it. It's easy to cut the retaining ring round the hose off with a Dremel and replace with a Jubilee clip (so replace the hose but not that end connector). |
12ty Member Since: 22 Dec 2020 Location: East Northamptonshire Posts: 14 ![]() ![]() |
Hi Thanks for the reply, I thought I was going daft or something. |
Yep, I was doing the thermostat mod as well. Before, the needle would just get a tiny bit past the blue. Now sits at 12 o'clock. |
