Home > In Car Electronics (L322) > Satnav / main display dead?
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
Hi all,
Edit: Car is a 2007 Vogue tdv8
My satnav / infotainment unit is acting up. For a while, it would occationally flicker and shut down, only to come back on little later. Now it's only showing the green oval constantly and doesn't respond to any knobs or switches. It's probably the head unit itself that's gone bad, but I would hate to get a replacement, only to find that the error lies elsewhere.
Has anyone had a similar problem and figured it out?
Cheers!
Henrik
Post #580650 21st Jan 2021 12:43pm
this could give you an idea of whats wrong,
https://www.fullfatrr.com/forum/topic24270.html ... - .- -.
Post #580655 21st Jan 2021 1:23pm
Henrik07
Wow, thanks! That's exactly the sort of information I was looking for. I'll give it a try and let you know.
Post #580659 21st Jan 2021 3:44pm
Henrik07
No, that didn't work. The same fiberoptic loop passes through a second module further down. Could this be at fault, and is this also something that can be disabled without affecting something important? This is possibly the TMC module mentioned in the wiki-thread. What's it for?
Cheers!
Henrik
Post #580778 22nd Jan 2021 5:26pm
Henrik07
Bypassing the bt module didn't work. Bypassing the TMC module didn't work. I then tried to join the two optical fibers coming from further down (TV? ). Bingo! Works perfectly now. No TV, but I have never even tried it, so won't miss it.
Cheers!
Post #581870 31st Jan 2021 9:30am
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
I don't know about the blank display but I had a flickering issue on my '09 L322. Everything on the display worked except no navigation.
In my case the issue was the navigation drive itself! I found a used on on eBay for $65 (USD). Plugged it in and no more flickering!
If you know anyone in your area with a compatible DVD drive, maybe you can try swapping drives to see if that fixes it. It's just 4 screws and 3 plugs to remove it.
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #581925 31st Jan 2021 8:25pm
Henrik07
Thanks, but all works now, except the TV which I never used anyway. I'll leave it alone for now.
Post #581987 1st Feb 2021 12:10pm
