![]() | Home > In Car Electronics (L322) > Satnav / main display dead? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
this could give you an idea of whats wrong,
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 66 ![]() ![]() ![]() |
Wow, thanks! That's exactly the sort of information I was looking for. I'll give it a try and let you know. |
No, that didn't work. The same fiberoptic loop passes through a second module further down. Could this be at fault, and is this also something that can be disabled without affecting something important? This is possibly the TMC module mentioned in the wiki-thread. What's it for?
Bypassing the bt module didn't work. Bypassing the TMC module didn't work. I then tried to join the two optical fibers coming from further down (TV? ). Bingo! Works perfectly now. No TV, but I have never even tried it, so won't miss it.
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 ![]() ![]() ![]() |
I don't know about the blank display but I had a flickering issue on my '09 L322. Everything on the display worked except no navigation.
Thanks, but all works now, except the TV which I never used anyway. I'll leave it alone for now. |
