Home > General > unlocking instrument cluster
found this on another forum and was wondering if anyone has or is willing to try this...
Getting access to the instrument cluster test mode.
Unlocking the instrument cluster:
1) Put your key in, put to position 2 (straight up and down, but just before kicking the starter on. Don't worry about starting the truck, you can start it once you're in the test mode.)
2) Latch the driver's seat belt to get rid of the "Fasten seat belt" message.
3) Press the right button on the cluster and hold for a few seconds. "TEST-NR. 01" will show.
4) Press the left button on the instrument panel once and the vehicle ID will show up, the last 7 digits of your VIN.
5) Add up the last 5 numbers to get your unlock code. For example, AB12345 would be 15. (1 + 2 + 3 + 4 + 5)
6) Press the right button until "TEST-NR. 19" shows up.
7) Press the left button once, "LOCK : ON" will show.
8 ) Press the left button again until "LOCK : xx" shows, where "xx" is the number you calculated in step 5.
9) Press the right button once. Now the cluster is unlocked and all modes can be accessed.
Here is a list of all the tests and what they do.
1) Vehicle info, what we used to get your Unlock Code.
2) Instrument Test. Very cool, try this with your engine off and enjoy.
3) Computer data
4) Current fuel consumption in liters per 100km and in liters per hour.
5) Average fuel consumption in liters per 100km and range.
6) Current fuel levels in left tank, right tank, and total.
7) Engine temperature, engine RPM, and outside temp.
8 ) Current speed in km/hr.
9) Current Battery Voltage.
10) Country.
11) Units
12) Average speed used to set ETA
13) Sound Test
14) Diag info
15) Binary port outputs
16) Oil temperature. Does not work in our trucks.
17) Vehicle specific data. Nothing meaningful.
18 ) More diag
19) Lock/Unlock Cluster
20) MPG Correction Factor
21) Reset all codes, date & time.
Post #62464 3rd May 2011 7:50am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
yer i have used this feature to check my battery voltage all the time (saves getting the multimeter out! lol)
Matt
Post #62468 3rd May 2011 8:16am
Laughing ... - .- -.
Post #62473 3rd May 2011 9:12am
dan_uk_1984
You found it on another forum? It's been here all along:
http://www.fullfatrr.com/wiki/Secret_Codes
Post #62483 3rd May 2011 11:57am
Rolling with laughter Embarassed
note to self , i should do what i preach...... ... - .- -.
Post #62484 3rd May 2011 12:02pm
dan_uk_1984
Do as I say, not do as I do!
Post #62485 3rd May 2011 12:09pm
what do you do then when somebody doesn't do what you do.... ... - .- -.
Post #62486 3rd May 2011 12:19pm
Search! It's at the top.
I use it alot. As our temp indictor is crap I've used it to check the engine temp. Nice bit of reassurance it's not over heating.
Post #62487 3rd May 2011 12:26pm
dan_uk_1984
I ask them not to do what I dont want them to do, so that next time they do not do what I do.
Post #62488 3rd May 2011 12:32pm
Post #62491 3rd May 2011 2:12pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Ah right, this is the same information you get on the 2006 onwards Touchscreen via the 753 code on the diagnostic panel. I'm assuming your method also works on the 2006 models anyway. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #62575 4th May 2011 12:26am
