![]() | Home > My Range Rover > Back with another Supercharged |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
or a dream even freudian slip there |
Yes remember seeing that in your earlier post probably is the diff might replace them both I have used GoS as you mentioned before for the p38 so might see what they have as the diffs are easy to swap out
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3162 ![]() ![]() ![]() |
I had a used transfer box from GoS but when you got up to motorway speeds the bearings in it really weren't happy. They were great in refunding me but it did mean that I had to strip it all again which was when I'd had enough and ordered a new one.
strongstuff Member Since: 26 Jun 2019 Location: North Wales Posts: 44 ![]() ![]() ![]() |
David,
I will give the boys in D&A a call might replace both or have them rebuilt as think it will be a year before I buy an SV dynamic |
Just heard back from Atlantic British. They've got the camshaft and can ship it to the UK.
Have you seen my post above RE: Cams?
That is nuts pity Mel has retired otherwise she could pick them up I dont know anyone anymore in the airfreight business so cant help |
StrongStuff - I hadn’t, I must’ve scrolled past that one. I’ll give them a call tomorrow |
No worries, he just text me to say to try here too.
Thanks |
Seriouslthinkingaboutit Member Since: 12 Mar 2022 Location: Essex Posts: 98 ![]() ![]() ![]() |
It’s a thought - is there anyone out there who modifies these engines RR or Jag for motorsport or Restomods. I found the cheapest new injectors I could get for my son’s Fiesta ST a while back was from Caterham as they strip them out for their 7 engines.
I’ve not found anything along those lines when Googling unfortunately.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 603 ![]() ![]() ![]() |
Hi David Could you let us all know how much of each product you needed to complete your project, it would help me/us decide what is needed for smaller projects. Also I was planning to just use Hydrate 80, and Zinc and then a top coat (maybe after what you have said using Mastic), so could you explain when or why you used the Deox products. Many thanks David Range Rover 4.2 Supercharged 2006 Ford Focus EcoBoost 1.5 2017 MG TF 2003 Previous Cars of note Land Rover Discovery 2 Jaguar Mk2 3.8 - Company car MG Midget 1974 - Concours |
