Home > Maintenance & Mods (L322) > P0171 on 2006 Supercharged
Page 4 of 4 <1234
Danwilderspin
Did the bg44k do anything?
Blowing exhaust before o2? Cracked manifold? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #604768 25th Aug 2021 6:03pm
RR_supercharged_702
United States 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Blowing exhaust before o2? Cracked manifold? Anyway I can find that out?
But I haven't tried the bk44k yet this posta clean up the injectors right
Post #604786 25th Aug 2021 7:39pm
Danwilderspin
Thumbs Up I don’t know the answer to that aside from a smoke machine up the tailpipe? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #604806 25th Aug 2021 9:47pm
RR_supercharged_702
P0171
Update on my 06 rr supercharged, I just installed brand-new cat on the driver side and 2 upstrream o2 sensor and the issue remains the same ugh, im really pulling off my hair, so I'm doing some search again p0171 I've check almost everything that involves with that cold except fuel related, can someone point to me where the fuel regulator is actually located? And I'm finally going to try that fuel cleaner, any recommendations would help me save this RR please thank you
Post #607993 3rd Oct 2021 2:59am
Danwilderspin
Have you tried smoke machine in the exhausts and intake looking for leaks? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #607998 3rd Oct 2021 8:59am
RR_supercharged_702
I have a smoke machine myself and found nuthing so I thought I'm doing it wrong and so I still brought it to a shop and they also found nuthing too but back then I 1st got the car I filled up the gas all the way and I notice gas was gushing out of the underneath my car, so I never paid attention to it but the code keeps coming back to p0171 and I completely swapped out new parts, except fuel related so I'm gonna start with replacing the fuel pump seal or oring,
So do we have a "fuel pressure regulator" and if we do please share the location I've looked on line nuthing
Appreciate it
Post #608043 3rd Oct 2021 1:26pm
Danwilderspin
Have you tried plugs and coils that side? AFAIK if you are in front of the bonnet with the engine cover off it’s toward the rear on the right - there is a vacuum hos coming from the supercharger piece to it and it had a plug on it a small cube i think Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #608158 4th Oct 2021 8:39am
RR_supercharged_702
P0171 it's telling me the fuel filter and fuel pump could cause this code.
Even the car feels and rides fine can it still throw this code? But I did notice the old fuel filter the previous owner replaced because when I bought the car it was left behind, im gonna replace the pump and filter any other suggestions.
I'll look into that fuel pressure regulator but I was going though images on Google of the fuel filter it looks like there's a fuel pressure regulator underneath the fuel filter is that the one?
Post #608228 4th Oct 2021 6:40pm
RR_supercharged_702
P0171 and 0088
Just replaced the fuel pump but check engine remains
Did a search does our car come with a " engine driven fuel pumps" ?
And again where is this fuel pressure sensor on our car, im having a difficult time locating that ugh stressful
Thanks again
Post #609520 17th Oct 2021 6:19pm
strongstuff
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Do you have a friend with a similar car?
I'm going to suggest borrowing a petrol cap.
I had that code on my 4.2 SC when I first got it, and also noticed that when I undid the petrol cap it hissed ... I bought a new cap and it has never done it since. 2008 L322 4.2 V8 SC Stornoway Grey
2006 L322 4.2 V8 SC Java Black
Post #609761 19th Oct 2021 10:23pm
RR_supercharged_702
What a petrol cap?
Post #609793 20th Oct 2021 11:21am
strongstuff
The cap that you undo to fill with fuel. 2008 L322 4.2 V8 SC Stornoway Grey
Post #609794 20th Oct 2021 11:21am
RR_supercharged_702
Oh mine is brand new from the dealership
Post #609795 20th Oct 2021 11:24am
strongstuff
Ah, it's not that then Sad 2008 L322 4.2 V8 SC Stornoway Grey
Post #609796 20th Oct 2021 11:30am
Danwilderspin
Did you fix this? I’m getting issues again now so I’m back on This path - the fuel pressure sensor is under the bonnet on the right has a vacuum hose and a plug going to it Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635578 27th Jun 2022 3:20pm
Page 4 of 4 <1234
