Home > Technical (L322) > Reduced Engine Performance...AGAIN!!! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8499 |
Doesn’t neccesarily rule out the coil packs. Swapping them side to side will just move the fault to the other side and it will still occur.
2nd Jan 2021 1:42pm |
Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 240 |
Cheers for the info. I did test the coils I bought and were all registering 1. I didnt do the test on the original coils which makes sense I should have done this.
2nd Jan 2021 1:53pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3061 |
Swapping the coils from Bank 1 to Bank 2 and still getting the error message could be normal if there’s an issue. Has the fault moved at all?
2nd Jan 2021 6:17pm |
I really need to take it for a longer drive. Swapping the banks over hasnt given me the missfire errors but saying that it might not show until the next time I start it up and drive it so will have to gove it a few days when I drive it. I will give MH a call on Monday see if he can squeeze me in for a plug in and investigation. Current Cars
2nd Jan 2021 6:40pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2214 |
Have you changed the supercharger coolant pump for a new one yet I see a few people telling you to but can’t see you have that was my issue and my buddies for £100 do it it will be due failure soon anyway Current stable:
2nd Jan 2021 10:56pm |
No havent done it yet. It is on the list of things to do. Po364 seems to be o2 sensor. Missfires can be o2 sensor so am now hedging that way. I willtake it into MH in Dartford. Go over everything that I have done
2nd Jan 2021 11:08pm |
I will get martin to do itwhen I take it in. Current Cars
2nd Jan 2021 11:10pm |
Yes definitely do the pump in the grand scheme of things a new one is dirt cheap - the only other time I’ve seen it is a badly fitted lpg system where they’ve tried an emulator or the fuel return isn’t right... Current stable:
3rd Jan 2021 4:39pm |
My car was delivered this afternoon. Read the fault codes, misfire on cylinder 1. Coil pack had melted. Replaced the coil, normal service has resumed
3rd Jan 2021 6:18pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Excellent news, its great when things go well like that. |
3rd Jan 2021 6:46pm |
Some guys have all the luck ha. Means I am doomed!!!
3rd Jan 2021 9:23pm |
Just chatting to someone else and thought - do you have lpg?
4th Jan 2021 10:13pm |
Funny you say that as someone orber day was behind my car and said was it lpg. Its petrol I havent seen or know any different and when I bought it lpg wasnt mentioned. Fuel pump been replaced and has been to two different garages and I havent been told any different. It was tunning really rich when bought it and had massive issues to start which ai have slowly gone through amd amemded
4th Jan 2021 10:43pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Any update mate |
5th Jan 2021 10:00pm |
