Home > Technical (L322) > L322 parking sensors
Malstar0780
United Kingdom 2005 Range Rover Vogue Td6 Epsom Green
Folks, hope the experts on here can help. My rear parking sensors have failed, I have replaced all the sensors in the rear bumper, I have also replaced the parking aid module, is there anything else I should check before suspecting the wiring to be at fault. The fronts have worked normally throughout the swap out process. Sorry if this question has been asked before, I did search but couldn’t find an issue like mine. The car is a 2011 TDV8. Thanks Malcolm.
Post #576095 14th Dec 2020 10:46am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
It's common for the rear wiring loom from the sensors in the rear to wear through so well worth checking 2011 TDV8 Vogue SE
Post #576119 14th Dec 2020 1:08pm
Malstar0780
I did check it when I replaced the sensors but looks like that’s my next port of call to revisit, thanks for the reply.
Post #576131 14th Dec 2020 2:26pm
Woofster
Canada
The wires for the rear parking sensors are pressed in place around some plastic tabs behind the rear bumper. Over time, the sheathing gets brittle and if it cracks/splits, the light gauge wires become exposed and can easily get frayed. A re-splice should fix this problem. 2010 RR SC
2007 RR SC
Post #576155 14th Dec 2020 6:53pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
I would start by removing the rear bumper and check the wiring as that’s the normal fault ( if sensors are all good )
Post #576168 14th Dec 2020 7:42pm
Jack last
United Kingdom 2005 Range Rover Vogue Td6 Zermatt Silver
Can you hear the sensors ticking?
If they’re new and no ticking sound must be a connection/wire broken
Post #576179 14th Dec 2020 9:30pm
Malstar0780
Everything is pointing that way, thanks for the reply. Looks like the bumper is coming off again.
Post #576181 14th Dec 2020 10:03pm
darrenm
mine work perfectly (2010 tdv8 ) and don’t click the only way I can check mine is using my iid tool
Post #576187 14th Dec 2020 10:26pm
Jack last
Must be a change in model years then my 2006 rears tick (front don’t though broken unfortunately) Laughing
Post #576194 14th Dec 2020 11:15pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I had this on my TDV8, broken wire where the loom passed through a hole in the crash bar. ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #576287 15th Dec 2020 9:00pm
