![]() | Home > Technical (L322) > L322 parking sensors |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
It's common for the rear wiring loom from the sensors in the rear to wear through so well worth checking 2011 TDV8 Vogue SE |
Malstar0780 Member Since: 14 Oct 2019 Location: Southend on sea Posts: 3 ![]() ![]() ![]() |
I did check it when I replaced the sensors but looks like that’s my next port of call to revisit, thanks for the reply. |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
The wires for the rear parking sensors are pressed in place around some plastic tabs behind the rear bumper. Over time, the sheathing gets brittle and if it cracks/splits, the light gauge wires become exposed and can easily get frayed. A re-splice should fix this problem. 2010 RR SC
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 ![]() ![]() ![]() |
I would start by removing the rear bumper and check the wiring as that’s the normal fault ( if sensors are all good ) |
Jack last Member Since: 29 Aug 2020 Location: Scotland Posts: 50 ![]() ![]() ![]() |
Can you hear the sensors ticking?
Everything is pointing that way, thanks for the reply. Looks like the bumper is coming off again. |
mine work perfectly (2010 tdv8 ) and don’t click the only way I can check mine is using my iid tool |
Must be a change in model years then my 2006 rears tick (front don’t though broken unfortunately) |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
I had this on my TDV8, broken wire where the loom passed through a hole in the crash bar. ---------------------------------------
