Home > Maintenance & Mods (L405) > Roof Rails with Pan Roof
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
Thinking about adding roof rails to a 2016 S/C AB with opening pan roof but searching for the none genuine ones brings up a comment that they dont fit with a pan roof, anyone know why please?
Thanks
Carl
Post #570214 18th Oct 2020 1:54pm
you've probably read these but just in case you havnt,
https://www.fullfatrr.com/forum/topic18718...=roof+bars
https://www.fullfatrr.com/forum/topic53335...=roof+bars
https://www.fullfatrr.com/forum/topic41146...=roof+bars ... - .- -.
Post #570216 18th Oct 2020 2:08pm
AFAIK you can fit genuine rails with a pano roof - its a one way thing though - the rails are a permanent fitment.
I think it's the only approved way to use bars.
Possible that after market ones encroach onto the roof or are in some other way not certified / approved
Post #570228 18th Oct 2020 5:17pm
725browning
United Kingdom 2017 Range Rover Vogue SE SDV8 Corris Grey
Hi Carlos. I was lucky enough to get hold of a black set and a Silver set of roof rails for a 66 plate 405 with sliding roof. I fitted the black pair in the end and both were none genuine. They fitted easily and it was just a case of marking the ditch rails once removed and carefully using a step drill. I think as Alister is correct that they won't have JLR approval but they seemed to work very well and took all the weight I loaded on them with no problems. Thumbs Up
Post #570239 18th Oct 2020 6:35pm
Crasher242
I have a set of non-LR roof bars on mine and they have plenty of clearance for the pano roof to open fully.
There is a post somewhere on this forum with photos of my install FYI Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #570636 22nd Oct 2020 11:52am
here it is,
https://www.fullfatrr.com/forum/post565329.html#565329 ... - .- -.
Post #570637 22nd Oct 2020 11:57am
725browning
Yes'plenty of clearance on fixed pan and sliding. If anyone wants a pair Ihave a silver pair spare that are brand new in the box with fixing kit. The black pair I fitted to mine and the silver pair are not jlr but I cant say ihave had any trouble with mine.
Post #570638 22nd Oct 2020 11:57am
