Home > My Range Rover > New Car For Nearly New Member
Classic Matt
Hi,
After a couple of months of searching I picked up this 2010 4.4 TDV8 Autobiography with 124000 miles on the clock. It isn't perfect cosmetically, but I can work on that. Mechanically it has a good history and seems pretty sound (touch wood). It is loaded to the gills with almost every possible extra which to be honest I'm not that bothered with, but everything works so that's a bonus! The choice of Autobiography was more 'right price, right time' rather than being something I searched for.
A nice bit of history is that the first owner appears to have been Jackie Stewart.
No doubt I will be a more 'active' forum member going forward as the ownership adventure unravels.
Matt.
Post #569546 11th Oct 2020 7:59pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Welcome, she looks lovely Thumbs Up Thumbs Up
Post #569560 11th Oct 2020 9:44pm
Nice looking car Thumbs Up
I didn’t realise they were gender specific Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #569562 11th Oct 2020 9:56pm
DrRob
Glad you found one in the end Thumbs Up
And now the preventative maintenance starts Rolling with laughter
Don't forget the main gearbox flush. I had mine Megaflushed to replace all the oil. No filter. Martin Hind at Dartford Transmissions and Autocare is your man. He didn't do mine as he was not set up back then. Ex LR guy, enthusiast and tranny specialist Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569577 12th Oct 2020 7:17am
Classic Matt
Thanks everyone. The moment I woke up this morning I was straight out to check for any fluid on the floor and to make sure the suspension hadn't dropped at all. It seems to have made it through the night without issue. Hopefully the paranoia will subside at some point!
Rob - thanks for your help and advice along the way too. It has already had a gearbox fluid change (multiple changes rather than flush) along with new filter but I will probably look to mega flush in the spring anyway. It has already seen Martin Hind too although for work unrelated to the gearbox.
Matt.
Post #569578 12th Oct 2020 7:27am
DrRob
No probs!
Did you say it might need the oil cooler doing? Any oil on the back of the engine undertray/circular cross member? Hot oily smell? Have you whipped off the pollen filter box for a gander yet? 2 min job Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569586 12th Oct 2020 8:53am
mpirie
"Hopefully the paranoia will subside at some point!"
You do realise it's a Range Rover? Rolling with laughter
Mike
Post #569587 12th Oct 2020 8:54am
Classic Matt
DrRob wrote:
No probs!
Had another look and can't see/smell any issue. It does look like oil was just splashed on a previous filter change as the oil marks I can see look ancient and are only by the filter. I'm going to clean it down though to see if anything reappears as I'd rather address the issue if there is one. There is no oil or oily film in the coolant etc.
Matt.
Post #569588 12th Oct 2020 9:01am
DrRob
Is it "bone dry" underneath? That's a big giveaway for an cooler issues. Mind you I had a leaky 2nd turbo too which added to the symptoms Big Cry
PS Baltic or Buckingham Blue? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569591 12th Oct 2020 9:09am
Classic Matt
Yes it is 'bone dry' underneath so fingers crossed!
Post #569595 12th Oct 2020 9:29am
DrRob
Cool Thumbs Up
Enjoy it! Open the second turbo regularly over 2500rpm Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569604 12th Oct 2020 10:07am
GGDR
Bone dry with vs without the under trays?
Looks nice Thumbs Up
More pics though pls
. Cheers, Greg
Post #569605 12th Oct 2020 10:38am
Classic Matt
Ah now that's the next stage of the question that I hope to confirm the answer to asap. Bone dry with undertrays in place and having looked right down the back of the engine onto said trays.
With that I'm trying to win at least a week of enjoying the car before I go further, but I will go further. I'm also planning to book it an at my local specialist for a once over to create a 'shopping list' of preventative maintenance to start budgeting for/factoring in. I'm reasonably handy with a spanner so some I can do at home, some I will let the specialist do such as I'm pretty sure it would benefit from a proper alignment as it just had all of the suspension/subframe bushes change but no alignment since and the OSF tyre is wearing prematurely on its outer edge.
Post #569619 12th Oct 2020 12:42pm
gettingold
Mike
The day you get rid it will stop Shocked visiting from www.rrsport.co.uk
Post #569707 13th Oct 2020 2:38pm
DrRob
Matt - who is your local specialist out of curiosity? Wink Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569710 13th Oct 2020 2:47pm
