![]() | Home > My Range Rover > New Car For Nearly New Member |
Classic Matt Member Since: 05 Sep 2020 Location: West Sussex Posts: 72 ![]() ![]() |
Hi,
No doubt I will be a more 'active' forum member going forward as the ownership adventure unravels. Matt. |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1447 ![]() ![]() ![]() |
Welcome, she looks lovely |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4327 ![]() ![]() ![]() |
Glad you found one in the end |
Thanks everyone. The moment I woke up this morning I was straight out to check for any fluid on the floor and to make sure the suspension hadn't dropped at all. It seems to have made it through the night without issue. Hopefully the paranoia will subside at some point!
No probs!
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 905 ![]() ![]() ![]() |
"Hopefully the paranoia will subside at some point!"
Had another look and can't see/smell any issue. It does look like oil was just splashed on a previous filter change as the oil marks I can see look ancient and are only by the filter. I'm going to clean it down though to see if anything reappears as I'd rather address the issue if there is one. There is no oil or oily film in the coolant etc. Matt. |
Is it "bone dry" underneath? That's a big giveaway for an cooler issues. Mind you I had a leaky 2nd turbo too which added to the symptoms |
Yes it is 'bone dry' underneath so fingers crossed! |
Cool |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Bone dry with vs without the under trays?
Ah now that's the next stage of the question that I hope to confirm the answer to asap. Bone dry with undertrays in place and having looked right down the back of the engine onto said trays.
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 ![]() ![]() |
The day you get rid it will stop ![]() |
Matt - who is your local specialist out of curiosity? |
