![]() | Home > Technical (L322) > Fuel went from quarter tank to empty |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
There's a TSB on the in tank pump and connectors doing this. Could be your problem, as could the pump falling about in the tank.
TheJohnnyH Member Since: 01 Sep 2020 Location: Kent Posts: 23 ![]() ![]() ![]() |
Thanks, I’ll check that out. |
J
Most helpful.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
common fault and lots of threads on here about it.
Thanks for the help. I dove into the tank and ended up replacing the first black plug which did the trick. Didn't fancy taking the whole pump assembly out as I'm just a humble home mechanic. Great tip about the carpet but I found it easier, less fiddly without the marigolds.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
Bloody love this forum |
erm.. did you not get diesel all over your hands? |
I did but trying to hold on to the tiny wire with slippery marigolds was impossible. It’s ok, I rinsed them off before dinner. |
