Home > Technical (L322) > Fuel went from quarter tank to empty |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
There's a TSB on the in tank pump and connectors doing this. Could be your problem, as could the pump falling about in the tank.
17th Sep 2020 5:06pm |
TheJohnnyH Member Since: 01 Sep 2020 Location: Kent Posts: 23 |
Thanks, I’ll check that out. |
17th Sep 2020 5:40pm |
J
17th Sep 2020 8:13pm |
Most helpful.
18th Sep 2020 7:47am |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
common fault and lots of threads on here about it.
18th Sep 2020 8:33am |
Thanks for the help. I dove into the tank and ended up replacing the first black plug which did the trick. Didn't fancy taking the whole pump assembly out as I'm just a humble home mechanic. Great tip about the carpet but I found it easier, less fiddly without the marigolds.
18th Sep 2020 12:07pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Bloody love this forum Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Sep 2020 1:00pm |
erm.. did you not get diesel all over your hands? |
18th Sep 2020 2:43pm |
I did but trying to hold on to the tiny wire with slippery marigolds was impossible. It’s ok, I rinsed them off before dinner. |
18th Sep 2020 6:52pm |
