Home > Technical (L322) > Hot smell after drive 4.4 tdv8
DrRob
Cam-Tech-Craig wrote:
Baltic Blue wrote:
I would put the bonnet lid in the vertical service position.
Remove the cabin air filter box, ..2x 13mm nuts., seconds of a job.
Find something to stand on and get a good look down the back of the engine so you can see the bellhousoing.
If it’s clean and dry then you have ruled out the leaking O rings.
Mike.
The OP has a 405 sir, not a 322 which I'm sure you're referring too above? Question
He’s got an L322. Seen it in person Wink Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567121 15th Sep 2020 9:45am
Sorry DrRob, thought it was in the 405 Technical Not 322! Dooh Whistle
Post #567123 15th Sep 2020 9:51am
to many late night's Craig.... Wink ... - .- -.
Post #567126 15th Sep 2020 10:04am
Absolutely Stan... Yawn Sniggering Thumbs Up
Post #567128 15th Sep 2020 10:08am
coopss
Coops, i think you should take her for a run then check the temp of each wheel and see if one is getting hotter than the others? This could point to a sticking caliper as mentioned above...
Secondly, Have a good look underneath and see if there are any signs of oil staining on the undertrays?
No undertrays or even an engine cover! Is there anything under there that would be clogged with mud? there was some oil on the front diff when I looked a few weeks ago and will look under there later.
Check the wheel/brake temp regularly as I’ve had an ongoing vibration issue - nothing wheel related gets hot after I replaced all the rear brakes and one caliper (the vibration persists but is bearable now) 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #567140 15th Sep 2020 12:53pm
D3Jon
I've noticed on my 4.4 TDV8 a *very* slight coolant leak from a hose connection on the RHS (offside) of the radiator. It's so slight that there's no drip (it evaporates off), giving a hot smell when you park up.
Might be worth a look down the front of the engine bay for any coolant loss from a hose connector or water pump.
I meant to change the hose on mine when I did the auxiliary drive belt tensioner and belts as I had it all exposed - but had forgotten to buy the hose Confused
On the list of jobs to do. Very Happy
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #567148 15th Sep 2020 2:39pm
coopss
Wouldn’t be surprised if part of the cooling did need some work.
Here is some oil (not running or leaking, just moist)..
Post #567184 15th Sep 2020 6:42pm
