Home > Technical (L322) > Hot smell after drive 4.4 tdv8
coopss
Anyone else get this? Car smells hot after any drive once it gets up to temp. Checked the coolant temp via IID and it sits around 99-103 C.
Difficult to tell exactly where is coming from but I can smell it when stopped and getting out of the car 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #567009 14th Sep 2020 12:25pm
Fox889
Hot, as in, "oily hot" then one would suspect the infamous oil cooler leak & associated 'O' rings etc.
If it's an overheating kinda smell & all indications are that the temperature is ok, then I'm stumped, sorry!
Have to say, that temperature looks a tad high, then I'm an old fart & remember when all cars had 88 degs thermostats in them, the more modern day vehicle may well run hotter.
There are far more learned friends on here that will come along in a mo. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #567010 14th Sep 2020 1:08pm
rjff
I'm with Fox on the hot and oily smell.
May be worth checking the hub temps to see if a caliper is binding, assuming you haven't already. Cheers
Richard
Gap IIDBT
Post #567011 14th Sep 2020 1:43pm
coopss
Doesn’t smell like oil burning and it’s not used a drop in 4K miles. Anyone know if there is a gearbox temp monitor on IID tool? 1995 4.6 v8, green/tan (long gone)
Post #567013 14th Sep 2020 1:52pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I'm sure there is - it's part of the fill-level procedure (at least on the 3.6). 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #567014 14th Sep 2020 2:01pm
Baltic Blue
I would put the bonnet lid in the vertical service position.
Remove the cabin air filter box, ..2x 13mm nuts., seconds of a job.
Find something to stand on and get a good look down the back of the engine so you can see the bellhousoing.
If it’s clean and dry then you have ruled out the leaking O rings.
Post #567031 14th Sep 2020 3:40pm
DrRob
Ditto on what Mike said... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567036 14th Sep 2020 4:40pm
kevinp
I used to get a hot antifreeze/coolant smell from mine. I had a lot of trouble bleeding all the air out, but I've also put on a new expansion tank cap and it doesn't smell anymore. Might be worth checking coolant level?
Post #567037 14th Sep 2020 5:07pm
coopss
Cheers all for the suggestions. Will check down the back tomorrow and the coolant level 1995 4.6 v8, green/tan (long gone)
Post #567072 14th Sep 2020 9:37pm
coopss
Here are pictures, can’t see anything wet. There is a faint coolant smell around the expansion tank but only when you’re right on top of it. No dampness anywhere. May need to get underneath
Post #567098 15th Sep 2020 8:44am
DrRob
Does it use coolant? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567104 15th Sep 2020 8:57am
coopss
Nope 1995 4.6 v8, green/tan (long gone)
Post #567106 15th Sep 2020 8:57am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
As Kevin has mentioned the expansion cap curing his "smell" it might be worth getting a new one if not too expensive, it may be that it's lost some of it's strength and is venting more than it should, hence the smell. 2011 TDV8 Vogue SE
Post #567110 15th Sep 2020 9:02am
Dooh! Rolling Eyes
Post #567119 15th Sep 2020 9:40am
Coops, i think you should take her for a run then check the temp of each wheel and see if one is getting hotter than the others? This could point to a sticking caliper as mentioned above...
Secondly, Have a good look underneath and see if there are any signs of oil staining on the undertrays?
Post #567120 15th Sep 2020 9:43am
