![]() | Home > Maintenance & Mods (L322) > Bonnet springs |
The bonnet wont simply spring up Jim as there is a manual safety lock... After that the gas struts hold the bonnet up! If they are failing then the bonnet will gradually close! |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Hi Craig
JohnK Member Since: 15 Mar 2020 Location: Hampshire Posts: 61 ![]() ![]() ![]() |
Try unwinding the rubber stops either side of the bonnet a little, worked for me. |
