![]() | Home > Technical (L322) > Strange problem after swapping wheels |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2635 ![]() ![]() |
The error occurring without moving suggests open circuit on an ABS sensor. Maybe a connector was bumped or there's a break in a wire that was moved. |
tinribs Member Since: 23 Jun 2017 Location: UK Posts: 20 ![]() ![]() |
I had this on ours. Completely unrelated to your wheel swap though...it was a split top intercooler hose... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
A split intercooler hose?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Have you read the fault codes? Only way to be sure what's going on. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6760 ![]() ![]() ![]() |
Ok, here’s what I’ve found today.
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 224 ![]() ![]() ![]() |
Did you lift the car off all 4 wheels at the same time. I had similar issues after a 4 wheel alignment apparently it can send the ride height sensors a bit off.
No, I did the front n/s first, then put an axle stand under it and did the n/s rear, as I only have 1 jack.
That is your issue ![]() ![]() Raid your piggy bank and treat it to 4 new tyres....55 all round will give it a comfier ride ![]() General Grabber AT3 in 255 55 20 next for me ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
I think you’re right, luckily I only need 2 new 255/55s as the ones I have are practically new. Got - 2017 SDV8 Autobiography in Loire Blue
Report back and let us know how you get on |
Just 1 small flaw in all this excellent logic.
No idea but mismatched tyre sizes are definitely a bad thing to do. Transmission wind up etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I'm almost tempted to swap them all back just to prove the theory and then get 2 new 255/55s |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35593 ![]() ![]() |
i would |
