Home > Technical (L322) > Strange problem after swapping wheels
DrRob
I like an experiment Thumbs Up
Bloody scientist (me) Rolling Eyes Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #564303 12th Aug 2020 1:18pm
Bloody engineer me, I need to know the reason why!!! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #564305 12th Aug 2020 1:27pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
For interest I used this tyre calculator, https://tiresize.com/tyre-size-calculator/ and it seems that the profiles give the following revolutions per mile
255/55x20 - 650 revolutions per mile
255/50x20 - 672 revolutions per mile.
So if you had the 50's on the back they would be trying to overtake the front!! (or something like that!)
I would have thought that it might be giving the transmission all sorts of issues!!
In one revolution the 55 section tyre travels 97.5"
In one revolution the 50 section tyre travels 94.3", so the 55 section travels 3.2" further than the 50 section, that must cause some wind up on the axles.
If you put 22" rims on 55's on one side they travel 103.8" so you could do donuts!!!!
Or go around roundabouts really really quickly!!
Post #564344 12th Aug 2020 5:02pm
Range Rover L322
Most RR sensors self calibrate, and then once they are set and happy they don't like big surprises outside of certain tolerances for wear/driving conditions etc. You have given them a shock by changing different sized wheels around so its brain is like a fritzing robot. The Land Rover mantra - don't fix something that's not broken. Hard to follow that advice when we all love to tinker and improve.
I suspect your car was settled with and used to the differing sizes. Hopefully the transmission and/or diffs are not knackered. If you really want to experiment (and, whilst it's interesting I completely recommend you do NOT do it) then swap them around again and see what happens.
Your actual solution is to put same tyres on all round and reset the ECU. Be aware your speedo may need recalibrating too.
Post #564376 12th Aug 2020 9:11pm
GraemeS
Australia
There will be different tolerances for front wheel travel compared with the rear which I expect are biased to allow the front wheels to travel further than the rear which occurs when turning corners. Thus smaller front tyres travelling further are less likely to trigger a fault than larger front tyres travelling less than the rears.
The fault existing without travelling will be due to the need to demonstrate by a drive cycle that the previous fault condition no longer exists.
I'm astounded that anyone would mix tyres an inch difference in diameter on a 4WD, totally unlike different wear on notionally the same diameter tyre which is never an issue.
NB. Sensors do not self re-calibrate to accommodate unexpected results. ECUs are programmed to tolerate a range of values and when the value is out of range then a fault condition is logged.
Post #564386 12th Aug 2020 9:54pm
Ok, so I reverse engineered my actions of yesterday (purely for experimental purposes obviously) by swapping the n/s front and n/s rear wheels. The result? No errors at all Shocked
Clearly the car doesn’t like what I did to it, so I’ll be investing in 2 new 255/55 tyres as soon as. Not that I’m doing much mileage these days - 50 miles last month But I’d hate to upset and confuse the old girl Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #564399 12th Aug 2020 11:06pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Good to hear you're sorted. Maybe the old girl was just trying to tell you not to mix tyre sizes, as best she could, before it did more expensive damage Thumbs Up Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #564437 13th Aug 2020 9:22am
That's so unlike JLR to be so charitable Laughing Got - 2017 SDV8 Autobiography in Loire Blue
Post #564443 13th Aug 2020 9:51am
Anvil
When I last had my tyres changed, the quite knowledgeable chap at Pro-tyre said that the sensors tend not to like a 2mm difference in tread-depth on a change for just this reason. Its possible that the system copes with gradual wear, and accounts for it. If you then swap your tyres, you've increased the differential between front and rear by a factor of 2x in one hit? Maybe that's why it throws a wobbly? FFRR 4.2SC/KTM 990SMT Current and cherished.
Honda Accord 2.4 Vtec touring. (Yeah, I know, think: Kids)
Mitsubishi Pajero Evolution Nut-wagon. and a Buell XB12R
TVR Griffith 5.0 (backed up with Vauxhall Carlton road barge for the weekly shop.)
Honda Integra Type R DC2 Possibly the best drivers car. Ever.
Mitshibishi FTO GPX MIVEC.
Honda CRX Vtec Mk2 -NO, Not the del sol!!!
Volkswagen Scirocco GT
Mini 1275GT
MG Midget (Heavily modified)
I'm going to stop now.....
Post #564814 17th Aug 2020 1:32pm
GraemeS
Australia
31" mixed with 30" is a very good reason for abs to get upset whereas 2mm is just a tyre dealer trying to sell more tyres.
Post #564854 17th Aug 2020 9:47pm
Anvil
He wasn't trying to sell me more tyres, I didn't need them. He just put that into the conversation from his experience. FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #564884 18th Aug 2020 10:53am
