Home > Technical (L322) > Strange problem after swapping wheels
I decided to rotate my nearside wheels yesterday and all seemed fine, until I took the car out to the shops. Xmas tree full of lights, HDC inactive, transmission error, suspension error and a few more. After coming out of the shops, same issue on the way home. Reset all errors, all seemed well, ran ok for a few minutes then the same errors pop up. Plugged it into the C-Tek charger on and left it overnight. Took the car out today and it seemed ok, until it all went haywire again.
What’s strange is that the HDC error comes up as I turn on the ignition but don’t start the engine. I’m assuming it’s no coincidence that this has only happened since I rotated the wheels but I’m puzzled as to what I could have done that would have caused this?
Anyone got any thoughts? Got - 2017 SDV8 Autobiography in Loire Blue
Post #564259 11th Aug 2020 10:12pm
GraemeS
The error occurring without moving suggests open circuit on an ABS sensor. Maybe a connector was bumped or there's a break in a wire that was moved.
Post #564266 12th Aug 2020 12:51am
tinribs
2010 Range Rover Vogue SE TDV8 Galway Green
I had this on ours. Completely unrelated to your wheel swap though...it was a split top intercooler hose...
Post #564267 12th Aug 2020 12:52am
mjdronfield
A split intercooler hose?
Giving HDC errors? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #564270 12th Aug 2020 7:02am
DrRob
Have you read the fault codes? Only way to be sure what's going on. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #564275 12th Aug 2020 8:52am
Ok, here’s what I’ve found today.
Battery charged over night. Turn ignition on, not stared the engine, HDC fault immediately.
From the IIDTool, these are the relevant faults
All the other errors are “U” type errors, indicating communication issues, which I reckon are associated with this error.
So far, so good. Looks like a speed sensor, but there are no more errors to indicate which one it is.
Next step, clear the errors, turn the car off and on and all seems well.
Looking at the sensor data, they look fine
So, I took the car out for a quick spin, everything seems fine until I hit about 30mph and bongs all over the place as before.
The strange thing is, the speed sensors are still sending wheel speeds on all 4 wheels as far as I can see.
This is most confusing.
One thing that has just sprung to mind looking at the speed differential between the front and rear wheels, is that I have different sized tyres on the front and back. The fronts are 255/55 20 and the rears are 255/50 20. I could see this maybe confusing the ECU but I can’t explain why the HDC inactive message would pop up even before the car is started. Got - 2017 SDV8 Autobiography in Loire Blue
Post #564281 12th Aug 2020 10:07am
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
Did you lift the car off all 4 wheels at the same time. I had similar issues after a 4 wheel alignment apparently it can send the ride height sensors a bit off.
Just a thought also after that, probably unrelated but very soon after the steering angle sensor failed.
Many faults throw up the Christmas tree of lights
Post #564283 12th Aug 2020 10:12am
No, I did the front n/s first, then put an axle stand under it and did the n/s rear, as I only have 1 jack.
I had already rotated the o/s wheels in a similar fashion and saw similar issues with HDC inactive messages but only once and having charged the battery, it never came back.
I’m just wondering if the fact that there were different sizes of tyres on the same axle was ok but now I’ve put the same size on the front and a different size on the rear, the ECU is getting a bit confused. Got - 2017 SDV8 Autobiography in Loire Blue
Post #564285 12th Aug 2020 10:14am
DrRob
That is your issue Whistle All tyres should be the same all round. It can cause major transmission issues too. A big no-no Big Cry
Raid your piggy bank and treat it to 4 new tyres....55 all round will give it a comfier ride Thumbs Up
General Grabber AT3 in 255 55 20 next for me Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #564286 12th Aug 2020 10:16am
I think you’re right, luckily I only need 2 new 255/55s as the ones I have are practically new. Got - 2017 SDV8 Autobiography in Loire Blue
Post #564287 12th Aug 2020 10:19am
DrRob
Report back and let us know how you get on Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #564288 12th Aug 2020 10:22am
Just 1 small flaw in all this excellent logic.
Why did I not get any errors at all when the 255/55s were both on the rear and the 255/50s were both on the front, as opposed to now, when they’re the other way around? Got - 2017 SDV8 Autobiography in Loire Blue
Post #564296 12th Aug 2020 10:54am
DrRob
No idea but mismatched tyre sizes are definitely a bad thing to do. Transmission wind up etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #564298 12th Aug 2020 11:08am
I'm almost tempted to swap them all back just to prove the theory and then get 2 new 255/55s Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #564299 12th Aug 2020 11:15am
i would Thumbs Up ... - .- -.
Post #564300 12th Aug 2020 11:22am
