![]() | Home > Technical (L322) > Strange problem after swapping wheels |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
I like an experiment |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
For interest I used this tyre calculator, https://tiresize.com/tyre-size-calculator/ and it seems that the profiles give the following revolutions per mile
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
Most RR sensors self calibrate, and then once they are set and happy they don't like big surprises outside of certain tolerances for wear/driving conditions etc. You have given them a shock by changing different sized wheels around so its brain is like a fritzing robot. The Land Rover mantra - don't fix something that's not broken. Hard to follow that advice when we all love to tinker and improve. I suspect your car was settled with and used to the differing sizes. Hopefully the transmission and/or diffs are not knackered. If you really want to experiment (and, whilst it's interesting I completely recommend you do NOT do it) then swap them around again and see what happens. Your actual solution is to put same tyres on all round and reset the ECU. Be aware your speedo may need recalibrating too. Last edited by Range Rover L322 on 12th Aug 2020 10:06pm. Edited 1 time in total |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2643 ![]() ![]() |
There will be different tolerances for front wheel travel compared with the rear which I expect are biased to allow the front wheels to travel further than the rear which occurs when turning corners. Thus smaller front tyres travelling further are less likely to trigger a fault than larger front tyres travelling less than the rears.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
Ok, so I reverse engineered my actions of yesterday (purely for experimental purposes obviously) by swapping the n/s front and n/s rear wheels. The result? No errors at all |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
Good to hear you're sorted. Maybe the old girl was just trying to tell you not to mix tyre sizes, as best she could, before it did more expensive damage |
That's so unlike JLR to be so charitable |
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
When I last had my tyres changed, the quite knowledgeable chap at Pro-tyre said that the sensors tend not to like a 2mm difference in tread-depth on a change for just this reason. Its possible that the system copes with gradual wear, and accounts for it. If you then swap your tyres, you've increased the differential between front and rear by a factor of 2x in one hit? Maybe that's why it throws a wobbly? FFRR 4.2SC/KTM 990SMT Current and cherished.
31" mixed with 30" is a very good reason for abs to get upset whereas 2mm is just a tyre dealer trying to sell more tyres. |
He wasn't trying to sell me more tyres, I didn't need them. He just put that into the conversation from his experience. FFRR 4.2SC/KTM 990SMT Current and cherished.
